1995 Air box Mods
I have the K47, custom silicon plumbing, and the filter minder. The filter mounts directly on the silicon elbow and then I reduce the diameter just in front of the ATT. So far, am not tripping the filter minder with the custom configuration.
Yes I do Les, I also have a filter from Leroy, I'm drawing a complete blank on the brand.
I needed the OEM fitting and couldn't find it in the pile-o-parts so...I used a threaded double hose barb to adapt my CDR ducting to the air cleaner ducting.
I don't recall the size but I think it was 5/8" (I'm out of town right now so I can't confirm).
I run an S&B draws from fender inlet and from the lid which is cutout and ducted to a reverse scoop on the hood lots of cool air.
As dust goes pany hose over filter works good!
The S&B looks like a good system, nice fit & finish. My next step will be that system.Do you use the paper or the oiled fabric filter?
