rlb
As far as the ATF cooler goes, can someone confirm that the top line at the radiator is the return line to the transmission?
I like the idea of running a 20-50 better than Lucas or STP. Still I don't know what oil the previous owner put in there, or what the oil pressure really is.
Since I am in NC a heavier weight oil should not be a problem, though we have had some lows in the teens lately. However i'll probably change the oil to a 10-30, get it hot and check the pressure with a mechanical gauge. If its low I might STP it and try 20-50 at the next oil change which should be in the spring.
So we are talking about big blocks and blowers now eh? Lets tone it down a bit, what is the best bang for the buck I can do for some HP on this 350? Right now i'm focused on changing all of the fluids and fixing the little stuff, gotta have it driving well and reliable. But its bone stock. I could at least put a K&N and maybe some headers on there.
Oh, and it looks like I have the 4L80E transmission. Code MT1 is listed on the sticker in the glove box.
Does this transmission have a 1/8npt test port like the 4L60E? Got a transmission temp gauge coming via UPS
Anyone know if a universal temperature sender like this one will work.
http://www.oreillyauto.com/site/c/d...ck=Search_N2346_1160312_-1&pt=N2346&ppt=C0331
Short answer: NO!. Get the proper one for the truck ordered in. That is my favorite parts place and they did get one in for the 1995 on mine. Dealer for the parts if they can't get it. This part is too sensitive to mess with anything else.
More or less it was the factory pump that had the defect. A new replacement for your year won't.
.. I don't set foot in AZ anymore.
