- Staff
- #41
LOL... I type too slow. What he said
Thought fuel filter was leaking, it was main line from lift pump to fuel filter busted under clamp. Cut off inch and put line back on.
Replace your fuel lines next chance you get. This includes the real fun IP to filter line, the fuel supply line and tank return line on back of engine. Also the IP line to the fuel return steel line. Your rubber lines are shot to break like that.
Cleared codes after removing OSF and drove truck. Instead of codes 18 35 and 49, now have 17 18 35 43 and 49. Any other suggestions. JiFaire said remove filter and plug back together. Just unplugged filter from Ip and PMD is plugged into Ip. Thanks...You should check for the Optical Sensor Filter. If its there remove it. And then clear codes and run it.
It looks like this and will be plugged into the top of the IP. You want to remove it and then connect the engine harness straight to the top of the IP.
