dbrannon79
I'm getting there!
on  the relay mod I linked above, to allow it to prime with the WTS, simply add a wire to the relay terminal 87a (center pin) and run it to the GP stud that feeds out to the glow plugs.   when you turn on the key the LP will run priming the system until the glow plugs have heated up.
