nealpellecchia
chinese rebuild, guy wont take the whole thing back. seems like i got low voltage. but installed a good wire to the s term the last time i had it out and whenever it won't start i just grab that lead and touch the + bat term and it cranks and starts easily. but, some times it doesn't work and you have to giggle the wire to make the solenoid engage and dis-engage very quickly to vibrate the circuit to find a good path and then it starts. but, sometimes this won't work. also when out once the guy who rebuilt the solenoid watched it run on the bench very slow and roughly like it had a jambing drive or a bad ground in the motor. also the contact washer, copper color not the silver color like the gm ones, was very thin after only one years use. he put in a new one that he "just happened to have on the bench". good for 4 days. then the guy who sold me the unit put a new cap on the solenoid, or it came out of a box, same. this guy had put on a new solenoid within the first year... took it off for me but it didn't last. I remember him hand operating the bendix mechanism looking at it with concern.
I think maybe the washer is inferior, or the drive gets stuck causing big current flow which burns the washer and cap, or intermittant bad ground in the starter motor...if you hit it with a hammer with the key in start you can get it to start. I think hitting it with a hammer can vibrate the solenoid as well as the motor to make it work not just the motor. or bad worn bushing near the gear end that he says is ok cause it never grinds. HELP i'm tired of getting in and out 60% of the time. and still too cheap to get a better one like others do and i read still have the problem. original never did this.
