n8in8or
Thanks, but not for this truck.If you find extra duckets in your wallet: Kingshocks.com
Thanks Jay! I'm pleased with the results - the truck gets a lot of looks every time I drive it and it's pretty fun to drive overall.Had not followed this thread in a while. Great job!
General commentary about adding a turbo is that it will improve power *and* fuel economy. IIRC, some of them came with turbos as OE, so it is not like you will have to re-invent that wheel. Seeing as this is a toy, your call on whether potential fuel savings is worth the cost of a turbo though![]()
That’s a good idea. Thanks!With the rear shocks measure the length at full extension, and full compression and contact Bilestien with those numbers. Would be amazed if they don't have something in that length available.
Well that is interesting. So I went to Rock Auto to see if either of those numbers matched what I bought for the front. Sure enough they do, but.....what’s really interesting is I see both numbers there. They list the other one for the rear of a 4x4 F350 that has front COIL springs. I hadn’t really thought about that before when lolking through the catalog, but no such bird ever existed. I would say there is a catalog problem. I’ll have to look up the specs for those and see how they compare. Thanks for the link.https://m.ebay.com/itm/BILSTEIN-SHOCK-ABSORBER-SET-FRONT-REAR-SHOCKS-86-98-FORD-F-250-F-350-4WD-TRUCK/291203903262?rmvSB=true&ul_ref=https://rover.ebay.com/rover/1/711-53200-19255-0/1?type=3&campId=5336121863&toolId=10001&customId=jffib0m770000b5200004&mpre=http://www.ebay.com/itm/291203903262&srcrot=711-53200-19255-0&rvr_id=1484801931781&_mwBanner=1&ul_noapp=true&epid=1930415518
Rear 24-016186
Front 24016179
(May or may not be right, found those on another site)
Sent from my SM-G892A using Tapatalk
It has a ZF5 in it right now. I have no history on the IP and injectors and I suspect those are partially to blame as well. We'll see what my fuel screw adjustment does. I'm hesitant to invest parts into this engine because I think it's ultimately going to get swapped out for a DT360.IIRC, that motor should mate to either a ZF-5 or ZF-6 which will also help with the fuel economy.
Sorry to hear that. Someone got a sweet rig.Yup. It spent too much time in the shop looking for love.
In the 40K miles that I had it, upgraded stuff to make it more durable / reliable. But there were too many repeat repairs of items that I would have expected to last a good bit longer and it turned into an economic decision.
I agree! I'm hopeful that he uses the truck as a learning tool. I included a full set of factory manuals with the truck so he has those resources and I told him to keep in touch and ask questions if he has them. He's really green (he didn't know what a fan clutch was and asked other novice questions), but he wasn't afraid to ask questions, so I take that as a good sign. My fingers are crossed.Was a neat old truck for sure! Hopefully he will do it justice (and not do kid type rolling-coal stuff with it).
The 400 sbc in that will be a 4 bolt main. The 4 bolts came in trucks and a couple oddballs like some impalas.I have a 78 SB Chevy, its bent and dented but it sure is dependable, K20, 400V8 and TH400 trans, NP203 with part time kit and double stick shift. One tommy lift installed and another for a spare. LOL
There is also a spare four bolt main 400 block in the shed, cleaned up at .030 over. Have the main caps and bolts, a set of heads that are nothing special. I also have a tuned port setup from a 305 I thought about upgrading to handle the larger engine, sending in the computer for a tune and installing all of that onto the 400. I have been rounding up components for this truck for some time but just seem to not have the want or desire to get after it. I do kinow if I sell it, I`ll miss it terrible bad, even though it sees only about ten miles a year. LOLThe 400 sbc in that will be a 4 bolt main. The 4 bolts came in trucks and a couple oddballs like some impalas.
That is one that is a good candidate for turning into a 427 cid small block- ya get tired of that truck, you might find an old school hot rodder that would pay more for the engine than the truck is worth.
