DieselSlug
Thanks, i'm trying real hard not to!
Got the clutch and bell all together and the tans along with starter. ARP bolts worked perfect on the crank. Jumped the safety switch pigtail as this new trans cover doesn't have the sensor. Got the fuel rail on with extended rubber lines.
All this progress there was some that was reversed. I installed the truck water neck on the intake. I need a mustang unit which I sold with my old engine. All found out the rubber hose will need to be clamped for the fuel cross over tubes. My tall valve covers are still not tall enough to fit over the poly lock girdle setup. So I'm looking for some cheap covers. Trans rear seal had a small cut in it so I removed it and will get a replacement this week.
Seems like the last steps of the project take the longest buttoning stuff up. Not sure if I will be able to fire this next weekend but I'm gonna try!
I totally forgot to take some pictures...
