Pepperidge
Member Advocate
How would weight distribution work on something so far extended...Like I said earlier...it looks scary, and I'm sure the engineers have it all figured out...I can live with that and the standard capacity...but that Weight distribution capacity is just nuts, to expect those two bars to have the leverage from that far away to turn the hitch to weight distribution...Oh there will be plenty of photos
Unfortunately there isn't any good way to move the chains up at all - my camper actually just rests on the hitch extension as is. The chains aren't providing any upward lift anyway, just side to side stability. The two 2" bars have plates between them that torque them together combined with them both being pinned into the receiver - The top tube is solid 2" for almost the entire length, then sleeved over for the receiver portion. The lower bar is 2" tube and is bolted together with the upper. I've seen many, many of these hitches in action, they look scary but after assembling and using one, I can assure you they are anything but. It really acts as an extension of the trucks frame, I've not found any movement or flex in the system yet.
