Back from the dead!
Well, I've fallen off the face of the forums because I was unemployed and madly on the job hunt, but there is a separate thread on that in the off topic section. Long story short, I'm employed again.
In my down time, I've done a few misc cheap things to the trailer.
Trimmed the fender skirts. Before & after.
GMT400 spare tire jacks welded to the frame for cheap stabilizers. Before I had the old school aluminum frame and adjustable screw setup. The trailer needed to be perfectly level and they took while to setup, etc. Well, I'm still using the aluminum base stand from the original setup to make up the height (they are rated for 6k each), but just having the ability to adjust the level of the trailer with these is eliminated the hassle of wood blocks to level it side to side, etc.
I also grabbed some old GM emblems from the wrecker's. I modified the "Camper Special" by taking the 10,000 GVWR off the bottom. I also picked up "Trailering Special" emblem but didn't hack it up.
Mounted on the trailer side
And I mounted a matching set on the cabinet inside.
Another little finishing item, I modified the original aluminum control cover for the fridge to fit the one that I replaced it with. I also drilled a smaller hole in it to check the pilot light without removing it.
A few weeks ago I found a leak in the left front corner inside. I suspected the roof or corner of the trailer, went through at the time and re-sealed the entire corner and re-coated the WHOLE roof. Then, last week we had a good rain, went to check the trailer and had the same leak up front. In a bit of a fit of anger I said $(#* it and started pulling paneling and insulation apart, and the front shelf since the water was pooling on it.
Turns out the front siding at the front window has a bit of a manufacturing defect that allowed water in where the siding overlaps and meets the upper window corner. Nothing some butyl putty didn't easily fix.
So, the next plans for the trailer are to re-panel the front, kitchen wall, bathroom and ceiling, then paint the interior walls a lighter color, and convert the remaining 120v interior lights to 12v.
