1978 Nomad Trailer Restoration/Project: 88GMCtruck is at it again.
As far as having a carrier in the back, probably not going to happen because you need toys in-order to use one of those.
Anyway, I picked up that Tekonsha Primus IQ last night for $60. Wired it in and viola, trailer brakes work. And the work very well. We have a nice 8-9% grade right by my house, after adjusting it went down that hill and the trailer alone can slow the truck down. So I'm beyond happy with that.
Also got the water system hooked back up. After disassembling and cleaning the gaskets, the pump no longer leaks and the one hot water line is good now that I re-flared the end of it. The only water system problem as of now is the hot water side of the faucet needs a new o-ring.
After getting the tank filled I gave her a tug to town. Drove through a variety of conditions, very windy 60MPH highway, tight alleys, downtown, etc and it tows nice. With the tank full I get no sway, even if I try to induce sway the trailer straightens right out. So good news is I don't need to buy another hitch that has provision for sway control. And the proportional brake controller does a great job, I hardly know the trailer is there when stopping.
No class today, just about headed out there to replace the 2x4 stud by the door, and start putting some furniture back in!
Sorry
i thought you had fourwheelers.
Glad to hear you got good brakes now.
So... just got to work. Spent the entire morning repairing the right side wall. It was a little more damaged than I originally thought, but I was in there so replaced what needed it.
Took some siding off.
To repair this at the door, and these above the wheel well.
Door area repaired, and additional stud added for the dinette to mount to
Other side of wheel well repaired, and another additional stud added for the dinette to mount to
Back together
Sealed up the water fill and reflector, and installed with new screws.
Sealed the door with putty tape
Oh and just as I was finishing putting the door back on, a guy from town was walking by. He stopped and commented that he's been noticing all the work being put into it and how he's never heard of someone rebuilding a trailer, and that I'm doing a great job. Was a really nice thing to say.
Anyway, after work the stove, dinette and couch/bed goes back in, then packing for tomorrow!
Sorry to leave everyone out of the loop for the weekend, but Friday after work I stayed up till 2AM putting the insides back together then cleaning and loading the trailer. This is what she's looking like on the insides now. It's all back together, everything cleaned (even washed all the cusions and curtians) and the camping gear loaded.
Anyway, once it was together, I then got up at 6AM and got more things ready in the truck and I was off! So I took the trailer to Ione, Wa (over 3 hours north of me) for a bachelor party. Everything went very well overall. on the way up, the truck towed the trailer pretty good. Had quite the diverse drive; started off in the rolling hills of the Palouse desert, making the little over an hour trek to Spokane and into the city. Made my way trough the city to meet up with the other camping crew, and headed farther north along some long flat highway, then onto a single lane highway in the foothills. Eventually we made it to Ione, Wa, 26 miles from the Canadian border. From there we headed to Lake Sullivan, which was up in the mountains aways. so lots of narrow winding, eventually gravel roads ensued. I even managed to ford a small creek with the trailer to get to the camping area.
All in all, the trailer towed quite well. It didn't sway a bit or buck, which was great as I did not want to spend the money on a weight distributing hitch if I didn't have to. The brakes worked good and the bearings didn't get too hot. The only problem I had with the trailer overall is my water pump isn't self priming (have to manually pull water through it) and I ended up puncturing a hole in a trailer tire with a sharp rock, but we patched that up.
The truck towed the trailer good on the way up. I definitely know it was back there, but I managed to drive smart enough not to hold people up on the highway, in most cases i didn't drop under the speed limit but infact had enough power to gain speed. Everything was in check, even with the temp pushing 95 outside and the AC blasting. Motor was running about 200 and the trans about 180.
On the way back, however, like and idiot I put regular in the truck and it wasn't happy. My truck doesn't prefer regular while it's hauling and I simply wasn't thinking about it. So, I had BAD spark knock on the way home. Combined the regular fuel causing spark knock, plus triple digit weather, the motor was heating up more than I like it. I ended up leaving the AC off and even at one point turning the heater on to help out. The motor saw a peak of 240 at one point, trans saw 200. Nothing horrible, but just something to make note of.
All in all, it was a good time and I can't wait to take the trailer out again. Soon I'll be investigating why my hot water heater doesn't work, take the fridge out and see if I can get it working, and do a few other misc things. I'm also looking up gears for the truck and contemplating a motor for it. There is a nice 383 built with 460 FT LBS and 390 HP for $2,500 and a 7year 70k warranty somewhat locally. But for now I'm just going to settle for gears.
The little waves in the wallpaper are from water damage, while the actual large curve is how the wall is, it comes to a point in the back of the trailer and they used the entire available space.
Great trip and great job on the camper.
Atleast the camper survived its first bachelor party. Don't know how much drinking was involved, but I have been to a few that would have destroyed a camper if we had been staying in one, instead of a tent. Not much you can do to a tent other than tear holes in it or burn it up in a camp fire.
8 or 9 cases (Costco, 30-packs), 2 bottles of Jager, 1 bottle of Pendleton's. I spy my white truck in the background of one shot. :D
Yes, the camper did survive the weekend, despite the amount of liquor involved. Luckily for the trailer it pretty much didn't see people in it at all, with the exception of using the bathroom. The man of the evening at one point did pop the center metal/plastic portion of the screen door out, but it wasn't broken and went right together. Everyone had their own tents and such anyway. I did let Devin have the honor of crashing in the trailer as well.
Didn't get many pictures at all of the weekend, but when we got there Devin promptly re-built the firepit into this magnificent creation. Prior it was just a big pile of rocks and dirt (no real pit there).
At one point we did run out of fire wood (the pit was large enough to cause us to consume large amounts of wood) so we pulled out an already downed tree with the red truck as well. :D I had to be gentle at first as the side of the truck was up against a tree . All the drunk party goers were giving me crud about being too easy on it, but Devin and I got this sucker out.
Oh, and everyone enjoyed the "sun" on the front of the truck. 8-HIDs work wonders for nighttime tree removal and sawing, let alone the gigantic game of beer pong with 5-gallon buckets.
On a trailer related note, I added up my costs thus far, and the grand total including the purchase, and licencing is $975.23. Not bad at all for what I have now. Probably going to have another few hundred into it when I repair the front and back walls, fix a few panels, and seal the whole thing up. There will be more to come, although at a possibly slower pace. I'm hoping to get into the water heater, heater and fridge this weekend.
What is the gearing in that truck? I'm sure I've been told, but don't remember.
I had my 22' TT during my era of my '84 K20 RCLB. 350, manual tranny......and get this. It was the heavy duty package and they put freakin 3.42 gears in it. I drove from Idaho Falls to Boise (300 miles) in 2nd gear and 40mph once because of a huge headwind. I did get to draft a semi at one point, but I couldn't keep up at one of the hills so back to 2nd gear I went.
Also had an older 8' cabover camper at one point too when I had that truck. Dad and I were heading out on a hunting adventure with me leading and him following in his truck. I rounded the bend on hwy 28 heading up the Lemhi valley and was slammed by a nasty headwind. Truck went from 65 to 40 in a matter of seconds. Once dad realized what was happening he went around and let me draft him the rest of the way. At least then I could maintain 50ish.
I don't have that problem now :D :D :D :D
My truck still has the stock 3.73s, which puts my crusing ability at under 60 in 4th or over 70 in 5th..... not very ideal.
I'm going to be ordering a set of 4.56s today and put them in early next week.
Nice work. In record time also. It would have taken me a good 6 months to do that.
I had to look at the pictures acouple of times. I have a brother in law that lives over in Rockport right next to Concrete WA. Last time I was out to visit him he had a camper like yours, mabey alittle longer. He told me if I wanted it I could bring my truck and pull it home and have it. After seeing how yours turned out I might have to take him up on it. I just don't know if it would make it all the way home here. Anyway, really a nice job on the trailer. Wish I had some of your ambition.
Great job fellas. I wish I had your help/knowledge. I forget to drain the pipes in my horse trlr with LQ and have been trying to fix them. Ir is really a pain trying to get to most of them, and has really tested my patience:mad2:
where did u get the mirrors from? i need those for towing my 38 footer
They are made by CIPA, model 95155. RVDirect is the cheapest place to buy them. http://store.rvdirect.com/rvdirect/details.php?ProdClass=Trailering+and+Safety&ITEM=3295155 They are out of stock now, but will come back in.
Thanks!
