- Staff
- #21
Umm did you read my post fully? I have a Trim Badged 2500 Suburban with the SF. This phenomenon of incorrect trim badge on the burbs has been noted in the past in other threads/forums. Unless this part of the discussion is semantics in that you are using the term 2500 figuratively to refer to a true 3/4 vehicle, whereas I am using the term literally as in the actual badge on the trim of the truck. Which is why I made the prior comment based on my own vehicle to ignore what the badge says and get under the truck. But you are correct in suggesting checking the door sticker in that my burb with the 2500 badge indeed GVWR's at 8050 and VINs out as a 1/2 ton. The rear spring pack is a different part number to the 3/4 ton and I checked with the local GM parts guy and indeed as we are discussing for the 1500 burbs is a heavy half ton spring pack.
Of course this then leads to two possibilities either GM had bad/funky days and the wrong badge was stuck on the side of the truck or a PO for whatever reason decided to change the badges. I have heard it was the former either way like I said get under the truck as well check the VIN/RPO codes and of course as you said check the GVWR sticker.
Cheers
Nobby
Yes I read your post. I stated that your comment about a 2500 diesel BURB with a 9.5" and 3.42's is incorrect as that is a 1500 diesel BURB. It is VERY common for people to swap out the door badges for 2500's because they get tired of people making comments about them having an 8 lug 1500. I have an uncle who has a gas 2500 truck that is 6 lug, and he swapped it out for 1500 badges because he got tired of peopel saying things about the 6 lug wheels and 2500 badges. Your BURB with a 8050 GVWR, 3.42 gears, and a 9.5" semi floating rear end is a 1500 diesel BURB, NOT a 2500 BURB. I seen K2500 in your sig, so I was pointing out that if this is the BURB you are refferring to, it is in fact a K1500 BURB. I should have clarified this better in my earlier post. You need to check the RPO list, if it doesn't have C6P it isn't a 2500 BURB. Then again it is confusing as the 1500 is for all intensive purposes a 2500 chassis but badged as a 1500 when it came out new, even though many change teh door badges as I'm sure many BURBS don't have DURAMAX/ALLISON badges on the door either like mine does. Don't go by what the badges are on the door unless you are the origanal owner and bought it and they were on it new, and even then it is a crap shoot as many dealerships changed teh door badges or added Z71 stickers and charged more money for them that way.
