SnowDrift
Ultra Conservative. ULTRA!
Is there a place under the hood to pick this up without splicing into something like the alternator wire?
Then use that wire for the signal wire to turn on the relay to Your full on 12 volt fuse panel.So I can use the pink wire from this solenoid? Is there a Deutsch connector to fit this?
why not just run the hour meter right off this pigtail? Are you just suggesting to power up an auxiliary fuse box for future use?Then use that wire for the signal wire to turn on the relay to Your full on 12 volt fuse panel.
Turn on the ignition and that turns on the relay to power up Your auxiliary fuse panel.
That was what I was going to do. just for future use to have something under the hood for key on power.why not just run the hour meter right off this pigtail? Are you just suggesting to power up an auxiliary fuse box for future use?
Are you talking about the fuel shutdown solenoid on the Injection Pump?It is a Pulse Width Modulated control ground from the PCM.
