Joey D
- Messages
 - 528
- Reaction score
 - 8
nice... any smoke with the ATT? your truck is a dana 60 conversion? how does it ride compared to the IFS? thanks for sharing...
looked like 11 seconds to 60...
Seems like.
Tach jumped at 10 seconds on the video and hit the 60 mph mark at 21-22 secs.
Still, pretty good for a 7000+ vehicle.
Seems that 0-60 videos are quite popular on the forum lately. Maybe I should record the OBDII data on mine and see how long it takes........
I did it for a comparison video for another guy who is running a different turbo setup, vs the ATT setup. There is some doubt as the the performance of the ATT
you said it needed more fuel...do you think if you were able to get that fuel to it that it would be a good bit quicker?
maybe a better tune would have given you what you wanted... or are you at the point where you are maxed out on fuel with your setup?
Just wondering, cause I know what it's like to drain the rails...on my dyno run of 484 rwhp my truck was starving big time If I'd have had my lift pump setup I have on it now at the time I dyno'd it, It would have been right around 525 rwhp...thats 41 rwhp difference just fueling it properly...I haven't dyno'd since then, but I will just before I replace the engine this fall...that'll give me a good base line to see what all the new goodies going into it have done...
Once over 2700-2800 it seems to run out of fuel. It's not so easy on the 6.5 to just do that though.
What I'd like to see is the results of this extensive testing here on the forum. I'd like to see this info first hand on a open forum, I don't need to PM anyone. What second hand info are you talking about Doc?
There were no insults intended, as a matter of fact I think it is the other way around, someone calls me out, I'm the one insulted. So where are all these facts on the turbo that is all I want to know, I just want to see whatever there is posted.
