n8in8or
Yeah, the weight is an issue, but it's hard for me to not lust after a dually. My stake truck with duals was so stable towing in the turns.....and just the looks of a dually gets me every timeMmmm...yeah, switch brands. : )>
I got the 5 gallon tank from AEM. Of course you can use whatever tank you want (the hose fitting comes with the tank less kit) but I was under a time crunch. I'll try to get a pic of it posted later.
I highly recommend water injection. And the AEM kit that you can get from Leroy was super easy to install. Other than the money, I think everyone is crazy not to get it.
Diesel engine+turbo+water/meth= perfection.
That every hour fill up was when I was injecting full time. After I adjusted it so that it was only injecting under acceleration or up hills, etc. it lasted much longer. And not towing, it lasted forever so a smaller tank in a non-towing rig should be fine.
Yeah, the 8200 lbs is certainly a factor. I was recently considering picking up a dually axle setup from a yard but I don't think I want to add more weight and this one ton frame handles my fifth wheel and any other loads that I have needed just fine.
Wow 5 gallons in an hour, I wouldn't have thought that much. Yeah I wouldn't notmally run it full time, but I'm concerned that when I go to haul the travel trailer with the Tahoe with the fuel I have now that I'll have to run water pretty much anytime I'm not idling, but we'll see. I'll just try to get the largest water tank I can fit. I'm hoping to hide it in the back behind the spare tire so it doesn't take up any precious interior space, but I don't know how practical that is yet. Also it will help to protect the tank from freezing during transition months (I doubt I'll run it or need it when it's freezing out - I can always put some meth in it though to prevent freezing). Good info and it looks like you have a nice build there, thanks and congrats!
