If You would want to pull those injectors then send them to @Rockabillyrat and have him check and adjust them, I believe a lot of that smoke could be eliminated.Smells burt af, I just think its fuel
I have a spare 90 motor in my friends storage unit, could I saw them in or not worth it?If You would want to pull those injectors then send them to @Rockabillyrat and have him check and adjust them, I believe a lot of that smoke could be eliminated.
100%!!Seems to me you're jumping the gun on a different engine. At least do a compression check
That’ll teach people to camp down wind from a detroit diesel.Well boys, im back after a weekend of camping, actually did really good out there (def need to replace my shocks though, insane a Bullnose Ford was more smoother than I)
Peep this if yall want, this was a cold start after overnight camping
View attachment 95407![]()
(4,630 elevation)
I was NOT expecting it to do thatThat’ll teach people to camp down wind from a detroit diesel.![]()
I havent seen diesel spots underneath me (yetYour definitely dumping a lot of fuel unnecessarily.
Not an external leak, an into the cylinders leak.I havent seen diesel spots underneath me (yet) oil as always
Man thats so unfortunateI agree, probably need to have those injectors leak down tested. I can do it for you, but it would leave your rig down for a bit unless you have a spare set to have setup and then swap them out. when it's doing that, if you give it a little RPM from the go pedal, does it fog the area for mosquitos or clear up quickly?
