Big T
I am trying to locate the remote control door lock receiver on my 1999 K2500. I need to due a voltage test on the “F” pin:
Some internet materials suggest the receiver is located under the dash on the right hand side of the steering column. I pulled two separate plugs there and they are not it. Other internet material suggests it’s behind the stereo. I’m asking the experts here where the hell is it?
I replaced the door lock actuator on the rear barn door because it stopped working. It was pretty rusted. The new one tested fine on direct voltage, but I get nothing once it’s installed. The GM manual has step by step tests which lead me to a vintage rest at the receiver, but I can’t find the receiver. All other doors work using the remote. Interior lights do not work using the remote.
