Rings and bearings while I have the engine out?
Many years ago, at the DOT, the service/night shift person hated his job and everyone around him. There was also a night road crew person working the same shift and with fair weather he too was hanging in the shop.
I had a SBC engine tore down, cleaned up and ready to go back together with all the components laid out on the work bench.
Came back to work the next day, laid the block side bearings in position, set the crank shaft into the block and give it a bit of a turn.
One of them @ss holes had taken the electronic scribing tool from the shop supers desk and scribed a line across one of the rod bearing journals on the crank shaft.
Had quite a discussion with the shop super and the field chief about this, field chief asked if there was some way to run it with that mar across the journal. YUP.
Took a fine tooth file and smoothed off the high spots.
A piece of 220 grit emory cloth. Clamped a piece of steel in the vice in a verticle fashion and using some pulling pressure drug the emory over the edge of that piece of steel, knocking off the sharp grit of the emory cloth.
Give the business side of the emory cloth a shot of oil and polished the journal with that piece of emory cloth.
I have always polished crank shafts using that emory cloth method as taught to Me by a very old time mechanic.
Unless the crank shaft has bad grooves around it, if it were mine, thats exactly what I would do to this cranking shaft too.
You will be surprised how nice of a job You can do, and its free.
Oh, on that SBC cranking shaft, the van that that engine was for, had another 100,000 miles on it when it was sent to auction in Helena where the head of the equipment bureau is located. The engine was running just fine with no issues and not consuming oil or rods knocking.
I rolled out the mains and am wondering if anyone has recommendations for rod and main bearings. I'm not looking for the cheapest option.
Also, since I don't know the 6.5 production history, I'll ask about my heads. I have the International Optimizer block dated 2003. Was International making the heads then too or just the blocks? I have the diamond pre-cups, but, apart from that, I don't know anything about exactly what heads they are. And does it matter anyway?
They made the heads too- better than gm heads but still can crack between the valves from heat. This is a likely location for the combustion gas into coolant. I’m now of the opinion that any head other than p400 heads will get the brass tube insert into the steam pockets. It simply seems it is not a matter of if but when every head begins to crack there. Such a simple solution to buy a ton more miles once the cracks start.
I prefer King bearings when possible, but there are other good ones.
Again- don’t buy any yet until it’s all pulled apart & inspected. You could have a cracked block in cyl 7/8 or something still unknown.
I'll look into King bearings. No crack in the block, so I ordered a set of Clearwater heads. I might go with Flepro for the gaskets and bolts, but does anyone have any strong opinions? What about Mahle gaskets? The block has most likely not been resurfaced. In the absence of absolute certainty, is it better to err toward standard thickness or +0.10"?
Thanks, Will. I'm itching to go with main and head studs, but maybe I'm just going overboard. FelPro bolts are about as inexpensive as it's going to get, so that's tempting.
I'm also considering replacing the nylon rocker arm retainers with another setup. I know there have been discussions of this here and elsewhere, but they seemed to be mostly at the point of trying something new out. Will, I saw some of your input on this. Does anyone know what's been tried, tested, and proven to work over the long haul? I'm a bit uneasy about just getting new nylon ones, and Harland-Sharps would be a hit to the wallet.
For rocker spacers.
I went with the very short 3/8ths bolts and self locking nuts, not nylock, with the thick grade 8 washers.
The bolts long enough so that the self locking dimples in the sides of the nuts gets a good bite on the bolt threads.
Have to feed the bolts outwards from the center of the shafts.
Use a screw driver wedged between the nut and the ID of the shaft to secure the nut from turning when tightening the bolts.
If the washers seem to large to give the rockers a slight bit of leeway, place the washers onto a bolt, or shaft, then spin them on a bench grinder to reduce the OD slightly. Sand off any grinding scratches to make the OD nice and smooth.
3 options:
Lowest cost is new plastic buttons. Rare they fail within 100,000 miles but it happens. Not uncommon to make it over 200,000 miles.
Marty gave you the middle option. Several people have run this for a long time. Medium cost, labor intensive, should be permanent.
Harland is the best option as long as you ignore your wallet.
It’s really a case of how much insurance $ do you want to spend to get that extra little amount of protection.
If going Harland then you can choose bigger rocker ratios for a better running engine. While the roller tips help in theory even at 1.5 stock ratio, the gain will be minimal. 1.6 will give you more of whatever you do- drive like grandma and go for mpg it will help, put your foot into it and you will get more power. Will you ever get enough mpg savings for to pay their cost? NEVER. And until you are running a bug turbo, cooled intake, bigger exhaust & more fuel- the cost of the Harlands aren’t the answer.
If you plan on doing the other stuff then doing them makes sense.
To me- I have had some horrible luck over the years being the 1 in 10,000 who had items fail that no one else did. So that insurance spent helps me relax better rather than worry.
Hi, all. I hit a snag getting the pistons and rods back together. One of the wrist pin bushings was cracked. I can't find a GM part number for it and am having trouble finding an out-of-the-box replacement. Enginetech sells sets, but they need to be honed to fit, and I'd like to find them sold individually, if possible. I'm assuming I can't just get a new GM rod without having it balanced with the others. Any ideas? Thanks.
Engine tech is a rebranding company. They buy over runs of other manufacturers and have them boxed in their name. It has been some years since I looked any up but I have bought parts from them by using their part number you can identify who the actual manufacturer is. The ordering part number will always be the same but they have a secondary number on each box that is used for this.
All wrist pin bearings should be at minimum checked for size, on these engines in my experience about 10% need a quick hone. Under $15 for a 3 stone hone - many auto-parts stores do the “free rental” where you buy it then return for full price, that would net about $5. But you absolutely want flat stones so if you do that, buy a new set of stones and just reinstall the used ones and keep the stones for a future use.
As for the new GM rod- you still have to check the clearance and possibly hone to fit spec. And as for the weight Balance of the rod - this is the worst unbalanced v8 GM ever created. If you had yours balanced before- then keep what you have & replace the bearing. If you never had yours balanced… I strongly recommend it.
If you just can’t afford to he balance at the machine shop- watch some YouTube videos how to weight big end from small end and rig up a hanger and break out the kitchen scale and flapper wheel in a grinder. Any first time diy job will get 6.2/6.5 rods & pistons insanely closer than stock. Close is not perfect but way better than crazy off numbers.
My advice would be to replace all bushings and start over with the balancing to confirm things are in spec.
If 1 bushing was damaged you may not notice the others are until it's too late, build once and have piece of mind...
I'm now replacing the engine mounts and am wondering if it's necessary to torque them down to final spec after the engine is resting on them. The manual says to torque to 36 ft lb with the engine off and then tighten to final after it's lowered. Because of the bolt and nut placement, that would be really tricky, maybe impossible, without removing the control arms. Anyone have experience to share?
I’m usually big on torque specs- but thats always been 3 ugga-duggas or if no air compressor one long rrrrrrrgggghhhhh on a long ratchet.
