CV Axle Seperation
Sorry lads, 'Pictures or it didn't happen.'
'Stray [truck] Strut.' Photo angle almost makes it worse than it is.
2" lift blocks and Old Bilstein 5100
New Upper Control Arms. I may still have the old style ones laying around. If so, I'll do a comparison picture post up.
So, after several hours of struggling to free the upper control arm ball joint from the knuckle I had to pause and think all this through and came to a realization that ya'll probably wanted to say but, were too say. The root issue is the differential's positioning (lowered) and I'm chasing my tail and making a lot of expensive choices to get around the root problem. The courses of action and path I'm on will only lead to more problems down the line. I know this in the pit of my stomach. It is a problem that could be solved with a trip to the strip yard for a couple of mounts (one would have to be cut from a donor truck) but still and the applied talent of a professional welder.
So, despite my preference for the look of a lifted truck and after my fruitless efforts with pickle forks, pry bars, Jack stands, air chisel, propane torch (not hot enough) and a lot of 2.5 Lbs. 'hammer time' with only a destroyed ball joint boot to show for it, I quit. Done, put a pickle fork in me, the fun meter was pegged. Yes I'd watched the YouTube Video and did what I've done in the past to no avail. I had called called Les Schwab, made an appointment for help getting the ball joint free and they said NO. They'd look at it and one guy would take a shot at getting it out but, no appointment.
I called them back after the decision to stop with the lift crap and made an appointment for them to install a new ball joint and or control arm with ball joint (labor time saved probably balances the cost of a replacement unit). They guy recognized my voice, laughed and said, 'first thing Monday work for you?'
I pulled the bump stops and ordered shorter units. These are almost 3" and so I ordered a set that's about 2" instead. The longer 5100 shocks are in as I will turn up the torsion bars 2" to get the half shafts at a better angle until such time as I'm ready to correct the Differential height. Thinking mid-September. Once the truck is on the ground, the weight keeps the upper control arms off that travel limiter and I'm not going off highway any time soon.
Truck's back. Les Schwab guy said it was easy, I'd done all the hard work. Turns out all I needed was a bigger pickle fork. Didn't know I was behind in the pickle fork department. Coulda saved a little $$ but, they re-aligned it since I did turn up the torsion bars an inch or so. Drives straight and with the new bump stops, doesn't ride rough anymore. Little progress here and there. Heading out to the Salt Flats later this week. Fingers crossed it stays together.
so they installed the lifted UCA's so the cv shafts are in line with the front hubs and axle? that should keep it together just keep watch on how much suspension travel it has going over big bumps, rocks, or dunes LOL.
No, Les Schwab will not install parts they didn't procure and there's no way they'll procure anything from Rough Country. Return Authorization received from RC and these units are going back.
So, I had them un-screw what I did to the OEM upper's and I've only raised the torsion bars by about an inch (maybe 1.5"?) so they don't contact the travel limiters.
The new bump stops, not being 3" in height but, rather, just over 2" no longer rest on the lower control arms improving the ride.
Half-Shafts are almost level...still upswept a bit but, the bump stops will prevent any excessive upward travel which, I and BigT think, allowed the Tripot end to separate. No dirt roads and especially dunes until I source a competent welder who can re-attach a lower differential mount to it's correct position and raise the diff. back where it belongs. I will be driving it on the salt though.
2" Lift Blocks in the back coming out probably tomorrow since they aren't needed. Anyone want them?
Pulled the 2” blocks out. Easier than going in. Truck is sitting level again. After the August / September road trips are over I’ll find a shop that will do the welding and start on getting the differential back up where it belongs. Man it has been a long circular journey trying to unscrew this situation.
Follow up. While changing the front rotors and pads a couple of months ago I discovered that the problematic upper control arm bushing on the driver’s side WASN”T changed out. In fact, the nut wasn’t even tight. Checked the work order for Les Schwab and further discovered that I had actually asked them to change out the Passenger, right side, unit by mistake. I’d like to say I was shocked but, too often, I’m really a bone head!.
Took it back to have the driver’s side done and he really struggled with it. Oh well, I guess the bright side is I have new upper control arms on both sides now.
Thats the dilemmas I get myself into. Be thinking left and blurt out right
Decided to go after the front differential who’s driver’s side output shaft seal was damaged last summer when I suffered yet another C/V shaft issue. It’s been drip drip dripping ever since. I acquired a replacement front differential assy from a parts yard and have been waiting to get after it. When I got back from my road trip I discovered that, seemingly, the seal had fully let go out of jealousy for getting after the transfer case’s rear output shaft seal first.
Big puddle of juice where, normally, there’s just a couple of spots! After initial mopping up.
Got parts and tools identified since I managed to bruise or crack a couple of ribs last week and wanted to minimize the stress on them as they were feeling better and I didn’t want to make things worse. Imphasis on the term ‘were.’ (Fail #1 as it turns out)
I looked up a video where the guy just pulled the output shaft out using a pulley puller and a 5lb slide hammer. Certainly a lot easier than swapping out the differential complete so I decided to just do that.
FAIL #2 Slide hammer technique probably works great but, only IF the diff is out of the truck. There isn’t sufficient space to fit get the slide hammer lined up given its length vs. the space available. I adjusted things and got the slide hammer threaded into the puller but, couldn’t generate the momentum or energy sufficient to pull the shaft out. I did manage to mash my thumb so I won a prize for pain and bruises but, not one for blood drawn. Double fail I guess.
Gave up and went after the brake caliper…FAIL #3 which has its own thread.
FAIL #4. The big puddle was/is from a leaking power steering hose/pump (new thread soon).
In the meantime, I had a thought, and @BigT confirmed it with a video of using the technique of a couple of ratchet straps to pull hard tension outwards on the shaft and then use a well calibrated BFH to finish getting it out. Great minds think a like.
This morning and probably the next couple of days are a bust because of Fail #1…ribs WERE feeling better, This morning, my ribs hurt worse than the day I injured them. Glad I’m retired and can just push the pause button pretty much whenever I need too.
