iamdave0887
Here Comes Chaos.....
I painted my stock steelies black with stock black center caps and chrome trim rings. It turned out pretty good.
you can wipe a heavy coat of vaseline on the rubber, then wash it off when the paint dries. anything petroleum based like maybe even tire shine products will not allow the paint to adhere to the rubber
Yeah, the tape/newspaper is great once you get it done, but it does take a LONG time. I only had to do 4 on the taco, but it was an afternoon project. It was a saturday in Georgia though, so there are worse things then spending time outside in the sun.I'm sure any short of wire brush/sandpaper would take the paint off of rubber pretty easy, however, masking would avoid it. My aluminum piece masked the tire in 4 separate spots and took less than 3 seconds to move it around the rim. Once the indented radius I cut it was bent (at a stand up angle) it hooked right into the rim/tire space and holds itself. Amazing how well it worked. I guess everyone may not have a 2'x2' piece of aluminum kicking around (super thing gauge)
The deck of cards idea sounds nice too. Newspaper and tape, is good for the 'die-hard' but way to long to mask off that round endge for me(times 6 tires)
Whatever method you do, you are still going to have to tape up the valve stems, but that's pretty easy.
Your center caps were came stock black?
