The design on the two chambers & air filter mount is creative and looks neat.
But I would clean it up & sell it. Punch a hole in the fender for a snorkle that hits a filter in an enclosed box on the fender well. Then to the turbo- then add an intercooler and from there to the intake manifold.
For the interior air filter box- talk to diesel hotrod shops and I’m sure they have frequent take outs from the new diesels which flow twice as much air as ours do. So you get better filtering and better flow, with replacement filters that will be in stock for years to come. Even without the intercooler at first that would be drawing in cooler air than sucking in hot air right now.
Oh yeah, and you could add a diy air shutoff valve for runaway protection.
looks good other than from what I can tell your cruising on a straight away and seeing you have to correct your steering frequently. are all the steering components good?
it's something sometimes we don't think about because it becomes second nature and we get used to the vehicle. I had gotten so used to how my 95 drives it became a normal for me on how it steers. that was until I acquired my 93, even though it still has most if it's factory steering and suspension components installed, my 95 has has everything replaced more than once. driving my 93 made me realize just how bad my 95 handles on the road. I haven't driven the 95 in several months, I could hop in it now and probably couldn't keep it straight on the road even if I tried LOL
Well sir, the drag link was replaced before my trip back home, shocks aswell.
nothing else was touched (OG gearbox) and the tie rods did look good back then
Any suggestions to tighten the steering though? Really do hate how i have a suggestion wheel, its so annoyingly noticeable.
If you have it up on a lift, have the fella check over all the joints. tie rods, ball joints, pitman and idler arms. also check the steering shaft coupling too. it's the rubber joint that is between the steering shaft and the gear box. those wear out and is sometimes the source of a sloppy steering wheel.
