JonnyTheKidd
Member
- Messages
- 15
- Reaction score
- 39
@dbrannon79 this is the new pump. the truck was running perfectly fine before i took the old pump out. i replaced it cause it was filling the valley with fuel. so the new pump was acting this way, so i put the old one back in, lined it up with the punch marks i made and it did the same thing as the new one. but yes the fuel is just sitting in the return line and not moving. ill run out and check the LP pressure quick and check for codes
