ak diesel driver
6.5 driver
How many hours a day won't make any difference. You could run it 24/7. It's the speed that'll get you.
Im so used to driving sports carsHow many hours a day won't make any difference. You could run it 24/7. It's the speed that'll get you.
3.73 gear ratioDepends on your gear ratio etc. you want to keep rpms 2000-2300
I know a lot more than I used to back when u first bought it sirI'm going to be blunt here...
You own a truck you don't know much about and it sounds like you can't work on it on your own.
You should consider selling it and buying a plane ticket home then get in another sport car, something you are use to and move on...
Thank you sir, this means alotHow soon do you make the move?
If you don’t have towing on your insurance- you might pony up for it now. Them cancel it once in NY a few bucks on insurance might be worth it if you aer really concerned- however most shops don’t know these old diesels so you have to check that before they pick which shop to tow to.
These engines are stout to run if not ran too hard. 65mph is probably tops you should be running at. A lot of hmmwvs running the 6.2 with 3 speed trans stay at max of 55mph, pretty sure your truck is geared better than them
Just remember: the guy honking behind you isn’t gonna help push the broke doen truck & not help pay for parts if you let him push you too fast. So take it easy on the way.
If ya have a 750-1000w (bigger is great) generator, those are great on camping trips to fire up and plug the block heater in. Keep in touch about the trip, I’ll PM you my number to call incase anything pops up along the way.
Obviously haul your tools with you and any spare parts ya have.
Ive made friends with those from the Reddit GC, got a few friends in Minnesota, Michigan, and PA (which is thankfully on the way back east) who own 6.2s (ive met with these guys aswell before)I agree with above- Yes 75 mph is ok.
But also- if you keep this rig you will HAVE TO become a proficient mechanic for it. There just aren’t many mechanic shops that deal with these anymore.
The only saving grace is you have a db2 instead of ds4 ip. This is what TSP is reasoning.
When ya get to NY, stay in contact here and expect that this rig will require more frequent and more expensive maintenance than say a Toyota tacoma or F150.
Expect to burn a quart of oil or two during that trip so check the level along the way. Not a bad idea to do an oil change/ lube before you go. Remember the trans, transfer case, & diff levels. Verify belts, hoses, hose clamps, etc are all happy before the trip.
As long as you own it, you need to remember that these older rigs aren’t like 2000 & newer units that you just drive without worry. You stay on-top of inspecting everything, doing the PMs, and still plan on more frequent hiccups.
Make sure you have a list of folks you can call along the way that can play rescue since you’re still learning the repairs.
Its a GearStar built Stage III 4L60E sir, not a 700r4, has a Shift Kit 4 on it, and an external cooler aswell (Hayden transmission cooler)Is that transmission a 4L80E ?
Or is it the old manual cable R4 four speed auto ?
If the latter then do not pull in overdrive with that transmission.
