Best to remove the intake manifold.How do I replace pdm harness that goes from engine compartment to the pdm? The one I guess is behind the head. I can't see it. Thanx
While the harness is disconnected,Thanx, I ordered a #5. Trying it tomorrow.
Bad PMD but also could be because of the missing resistor.Waiting on resistor. Ran it today, drove 10mins., got fuel, dro e 5 mins to the dump, idled for 10mins. Left the dump drove 30secs., and shut right off. 25-30 mins later, started back up.
Jumper the lift pump. Or just install a toggle switch to run the lift pump on demand. Cracking the bleeder and then getting in the cab just sounds like an air problem waiting to happen. Not to mention a mess.I put 3 new pdms in. Yeah, as soon as it gets, i guess, running temp. Shuts right off. I opened the bleeder on the top of the fuel filter turned the key an no fuel, cranked it and no fuel. 30 mins later, fired right up. Takes about 5 secs. To start when cold. Not bad. Then right up after warmed up, idle forever, but when driving, it's do
Jumper the lift pump. Or just install a toggle switch to run the lift pump on demand. Cracking the bleeder and then getting in the cab just sounds like an air problem waiting to happen. Not to mention a mess.I put 3 new pdms in. Yeah, as soon as it gets, i guess, running temp. Shuts right off. I opened the bleeder on the top of the fuel filter turned the key an no fuel, cranked it and no fuel. 30 mins later, fired right up. Takes about 5 secs. To start when cold. Not bad. Then right up after warmed up, idle forever, but when driving, it's done.
