MrMarty51
Nope. Pump is coming off and getting checked out.Marty your reman IP worked for me during my brief test runs. At worst it is some sort of seal causing the problem. The hard components should be fine. Do not condemn it.
I was looking into the DB2 system.My .02...
Not worth the risk/ trouble/ hassle buying a "new reman" DS4. Doesn't matter if all seals and small parts have been replaced, if the H&R is worn then it's shot. And if there are no new DS4 head and rotors available then any reman unit is on borrowed time.
I understand buying one of the last new DS4 pumps is an easier job than a DB2 conversion. You can buy a core for cheap and send it to a pump builder. Quadstar used to have "250 HP" DB2 pumps for sale for around 800 bucks but I don't see them on the website anymore. You can do the conversion without needing a standalone trans controller so long as you leave the APP in place. You have to fabricate your own way of attaching the throttle cable to the pedal but the trans will shift even with the DS4 gone. Not sure how smooth it will shift but there are folks who have done it.
Second thing that would really help with the DB2 conversion is scoring the rare '96 tstat crossover that was single stat and block off but still routed back around the A/C compressor. It will leave a lot more room for the throttle bracket to clear. And if you upgrade to a different upper intake you'll have much easier access to the pump for timing adjustment.
Yup.I wouldn’t do a db2 conversion to eliminate problems and not buy a brand new one.
Last I saw the trans controller is $600.
You don’t need the rare 96 crossover. If you find one great, otherwise look at the link in my signature. You can accomplish the same thing with that, a couple diy brackets, and some fittings and a bit of 1” hose.
I was under the impression there is new head/rotor & complete new ip being made for the ds4. I could be wrong.
QuadStar Tuning sells the pumps remanned by Flight Systems.Are there any places that would rebuild either of your injection pumps that you could overnight it to And get it back in decent time?
Could your air infiltration be after the fuel supply hose to the IP - at the nipple or the fuel pressure gauge T area?
15 max fuel pressure.I know there's Triangle Diesel in Irwin Illinois and the place in Michigan I used to use.
I don't know that either are still doing 6.5 Diesel injection pumps.
I sold the 1996 with rebuilt injectors and injection pump for less than the IP was worth.
I know Triangle Diesel was still rebuilding 6.5 Diesel injection pumps at that time.
I'm sure there's a few others that are trustworthy.
The only way you could find cost and turnaround time would be to call them.
I'm not sure what shipping would be to overnight an IP.
I've seen times where a fittings wouldn't leak under pressure, but would suck air.
How much air pressure can you put to the pump inlet to test for leaks?
I don't know what damage could be done, putting air pressure to the pump inlet.
Or how much air pressure you could put there without doing damage. 50 lbs? 100 lbs?
That all looks to be simple enough.
Is the roughness or hesitation gone?
Yup, just a mighty sweet runnin truck, once again.Is the roughness or hesitation gone?
Marty, I find that persistence wins the day and you most definitely got it. May God bless this 6.5 Optimizer with a long life.Its a runnin mighty fine.
Took it for a 16 mile run and its never run better.
Thank You everyone for putting up with me and alla mine shortcomings.
It now feels and sounds so good it’s ready for the Ohio journey.
