Possible ok block,crank, ds4 for sale
Will L.
Boulder City Nv
Over on hummernetworkforums.com a guy with 6.5TD centermount engine is for sale.
He blew a head gasket, one head toast, other one cracking between valves could be brass sleeved and ran 100k or so. The block is a May 99 so supposedly latest version GM ever made.
You’d have to verify cylinder walls, main webs, etc not cracked to run the block.
110,000 on the thing and it has a ds4- so that might be worth $100 for a spare or someone in need of a cheap runner to last a little while.
He is in Munster Indiana.
I don’t know the guy personally but never heard anyone cursing him…
Depending on the Injection Pump history, that could be a bargain
Ds4, well taken care of, 270,000 is about it. Db2 if well taken care of can be 325,000.
But many things shorten that life.
And that is them working but not working well. Efficiency drops after 150,000 for both.
So probably not worth installing a $100.00 seal/gasket kit into my DS4 pump with 270,000 miles on it ? ? ? ?
@Will L.
Could You contact Him and see if He would take $100.00 for His IP ?
With only 100,000 miles on that pump it would take My engine a long ways before that portion of the equipment needs attention.
You can sign up there- its a good forum for some stuff like this. It’s free and even uses same platform as this one.
The moderator there was (is?) a member here also.
There’s a thread right now about a guy in Northern Nv who is working out a deal for a TON of 6.5 parts. The guy who owned UROVA (big name in hummer stuff- makes the best centermount turbo available) is getting rolid of the rest if his 6.5 stuff to a member there.
That forum is less active than this one (maybe 1/5 as much) but still has good stuff. Chris of TSP has an awesome thread of two p400 builds he is doing for a couple members there.
Y’all should seriously join. This isn’t like two enemy sites- haha.
I’ll let him know in a pm to contact you if interested
Okay, I’ll sign up but dont know how well received a person with just a non military truck type wehicle would be received. 🤷1750540995196.png
I signed up over there.
I figure when I’m allowed to, do an intro, I’ll offer that I do have tools and some ability if anyone is ever in the area and needs help.
Probably not much else to offer on a Hummer site.
Although I would also love to have one of those wehicles, even as frustrated and down as I get with this pickup truck.
There's a guy in Alaska on this Facebook thread, that claims to have a new in box DS4 IP with black pmd mounted.
He didn't say if it was for sale or anything. He just stated that he has one.
The thread is a guy looking for an IP for his 1993
I used to belong to that group.
But then I dumped fakebook so now cant see whats in there.
QST does have three new DS4s available. IDR but if I do rememer correctly the price is $27??.?? Dollars.
Turns out he was just bragging that he had one
I got this injection pump purchased today.
I also have a brand new one coming from QST too.
Flight Systems pump will be going back to them.
Thinking I’ll install this used pump and hold the new pump.
I have learned that the seals are good for only a number of years so in the meantime I’ll dismantle my current IP, the original unit, and do a rebuild on it so I can get familiar with the tear down and back together process.
We shall see. 🤷😹
The used IP arrived yesterday.
Appears to be a mighty fine unit.
I now have another known good spare to send out if anyone needs a test unit.
It does have a black box Stanadyne PMD mounted on the pump that I presume was functioning.
I will send him a message and ask if that is a functioning PMD.
Never know. I never bothered to remove a bad one from the IP.
And used them until I had to use the spare.
