Best batteries for -50°F weather?
nycxjeremyy
Rapid City
Looks like my batteries are going out, I'm currently stationed at a place where it can get up to -50°F in the winters (Midwest). No, the Dorms/Barracks here do not have outdoor outlets, so i won't be able to use a block heater.
What is the best extreme cold rated battery you all recommend?
(1985 6.2 Detroit Diesel)
I use batteries, two connected in parallel. 78DT-850 95 Ah My batteries are "Delkor" brand, they are produced under the "American", "Deka 778DT" brand. They are not serviceable, they do not have a plug for draining and filling the electrolyte. If you have a choice, buy a battery with plugs, you can increase the density of the electrolyte for winter work.
View attachment 92346View attachment 92347
I knew there’d be a good response from the coldest city on the planet.
Thank You for stepping in.
Yes- I didn’t want to say using a webasto instead of getting the best batteries you can. I meant to imply just the best batteries will not be enough.
If you are not familiar with the powermaster 9052- lesrn it is a major difference in cranking speed, and also your factory sized battery cables were grossly penny pinched by design. There are threads here that cover both of those major improvements to help you start-
Also hoping you understand the AC Delco 60G and using increased glow time from them - DO NOT go for things like insta heat plugs that can destroy your engine.
