JohnShead
Member
So, after getting my truck running with an AC Delco rebuilt IP it was running beautifully pulling our 6800 lb travel trailer, lots of issues with cooling but this pump made it run better than I ever remember (I was running on a bad IP for quite a while). Then I fogot to put the cap on after topping off the coolant for the 1600 mile trip home from our daughter's wedding. Climbing out of Custer, SD it blew something and boiled out all of its coolant. It sat for couple of years in the garage until I could get around to pulling the motor and tearing it down, and when I did the damage repair, with mods, would cost nearly as much as a brand new Optimizer 6500 from Leroy. So I bought the long block, I picked it up last month in Franklin, OH. I've transplanted my Phazer Gears and FluidDamper to the new motor. I got a billet steel flexplate and assorted ARP bolt kits from QuadstarTuning.
The problem is, I still want the mods, one of which is flashing removed, which requires a complete disassembly. Now since we're here why not put in gapless rings, main studs (not sure about girdles), head studs, MLM head gaskets (one thickness over stock for a little less compression), roller rockers, and I really want to have it balanced. I've read about it and am pretty confident I could do the reciprocating parts but the crankshaft is definitely not DIY so I need to find a shop for that.
Am I crazy or should I just drop it in the way it is?
