Turbo Thread links - aka choosing a turbo
Will L.
Boulder City Nv
My intent is to link together the most useful turbo threads for people trying to determine turbo comparisons into one thread rather for reference. Kind of a turbo sub thread in the performance section. If you come across any comparison threads you feel relevant, please add the link.
A picture request is made - attach any you open as full size pic instead of thumbnail whenever possible even if you post it separately as we have lost many pics through the years in updates and many small images get where they can’t be opened later.
This link is to the HX40ii kit @racedaymechanic created.
His kit works well with the cko as well as authentic hx40. I never owned one but seen one in use. Any current input on how long these turbos lived, regrets of the cko vs authentic or happy to have saved the $ and rebuild-ability would be great info from folks.
There is discussion of this HX40
The last link a comparison of ATT to HX40ii was spoken of but not shown.
Here is @WarWagon doing a dyno comparison of the two.
If my friend from Az still has these files in his computer- a request to repost the dyno numbers in a modern pic at full image please at the end of your thread please.
With the ATT- I’m not sure who currently (if anyone) is still selling it. Still a very serious contender of a choice imo. Years ago I spoke to Dennis aka @Slim Shady about using my Hummer as the test mule for fitting the ATT but it never happened due to my chaos in life. Hummers/hmmwvs are incredibly tight fitting. As centermount a custom dog house would be required, possibly using the banks sidewinder exhaust manifold could work as its in use on a couple hummers with hx35 turbos I have seen. With respect to that, I haven’t found threads on that in hummers yet but the results in hummers is similar to pickups- just account for the 37” tires and the 5:13 gear final ratio. Do the math on the pickup threads found for comparison. If someone knows of a goof thread on hx35 options, please post the links faster than I can.
Back on ATT - I am still hung up on wanting to add an external waste gate as an option because offroading there are times you want to force boost for torque — think butterfly valve in the pipe st the turbo to narrow flow like a twin scroll vs open one. When open it would allow the normal non wastegate operation of the turbo there by negating any argued low rpm side affects of the turbo. Controlling it magically makes it become a variable turbo… so not the easy diy project. My uses of it would be crude therefore a choke cable could do it for me in the rare instances I would use it.
I absolutely love the free flowing, minimal heat inducing activity of this turbo. Hummers/ hmmwvs are far worse for fighting heat than square bodies or gmt400. So the ability to outperform the gm6&7 center of turbos and reduce the iat would be a massive win for hiway use. The same tunes in pickups works in hummers.
Any db2/db4 thread links with ATT would be awesome if you see any.
No link but side note for centermount - myself and several others have often thought a t4 twin scroll centermount very similar to the ATT would have been the ideal stock turbo for the 6.5. Magically finding it- well we didn’t have searchable data bases that might exist now.
Something that might also be of good info is a comparison on them for the different use cases. for the casual every day driver vs the towing or hauling. something that points out which ones spool up at lower rpms and higher.
for myself, I like to hear the spooling but have no need for one in the towing or hauling section. My only reason for not trying to get into anything larger than the factory GMx. it's funny how I can't hear the turbo on my 95 with the 4" exhaust, but I can with the 93 which is all stock exhaust.
BW s300SX-E 62/74 was my choice. I went with a twin scroll .83 A/R T4 Gated turbine housing that will have a fully divided 2" hot side. I really think the S300 is a great turbo option for these. Could even go with a smaller s354.
If you can elaborate on this please. I understand basics of turbos, and see details like t4, twin, etc but rather than my 2c on them - I prefer your explanation and experience with it for my better understanding as well as others.
Draw backs besides physical size (request for dimensions of it) like gmx fits easier.
More or less compatibility with db pumps, stick vs auto, etc. obviously the ds4 having tune-ability helps when you can get them tuned just right. Db- not an option so we play with androids (puff limiter). I know you (like me) run db pumps -
So what fueling range limits do you see with this turbo- smoke before spooling, only supporting up to Xcc of fuel/ power.
Either pump can be tuned to handle similar turbos. The DB2 just takes more work to limit the lower end fueling and still have enough in the upper end. The aneroid can help with that. Stick vs auto I would normally run a small turbine housing on a stick since you have to spool it every gear change.
The way I see it the 6.5 makes 3-3.5 hp per 1cc of fuel. A 110cc (at peak hp) pump should be good for 350hpish. You need to find the right turbo that supports your HP goals and match the turbine housing to you application and rpm range. You want to keep the turbo in its efficiency zone.
For me my HP goal is 400hp, I calculated the CFM of air and CC of fuel needed to reach my goal. The sx362 fits what I'm trying to do. BW has compressor maps that are helpful. The turbine housing you have to figure out on you own. I'm running a NV4500 so i when with the smallest T4 twin scroll i could find. Keeping it divided should help it spool, and I'm running stock heads. No need to port these heads in my opinion. Air velocity is more important that volume to a certain point. our heads can support 400hp NA. no need to open them up.
ATT, CKO HX40II, and something off a 4 banger ... oh wait that's a GM3 Asthma Attack turbo.
I believe the ATT kit isn't made anymore. The Mitsubishi TD-07 turbo and knock-offs without mods to fit a 6.5TD still is.
It was a hellva stigma to break "use a better bigger turbo" Neither the ATT or the HX40II would leave the line like the GM3. However once the engine chokes it's way past 2000 RPM it would run the GM3 down and then run it over. Esp loaded. The ATT once lit would pull hard till redline. The HX40II was building more backpressure and using higher boost numbers for the same power. The MPG loaded towing was MISERABLE SINGLE DIGITS (7MPG) with the GM3 loaded towing grades and couldn't maintain the speed limit or 20 under. The ATT turbo put me into double digit 10.4 MPG towing at the speed limit.
Don't forget being like 1 of 2 (Well at least the 2nd to have done it) that put a spool valve on this engine with an ATT.
And the first crazy SOB to put a Yank behind a 6.5TD to overcome the ATT big turbo no boost below 2000 RPM. I get a phone call about that once in a blue moon.
On a budget I would do a big turbo and a Yank stall converter skipping the spool valve. Today there are better turbo choices available than around 2013.
Don't forget the discontinued Peninsular Engines towing turbo. Said to be a Schwitzer s300 series turbo.
(DB2 small plunger 6.2L pump.) Dyno run with a DB2 and the ATT.
Videos including what member 6.5L did with a spool valve.
After throwing a Yank behind a 1993 DB2 with an ATT. This was a 6.2/6.5L hybrid 6.2L longblock small precups and all including a 6.2L small DB2. More fuel and bigger precups would have made a big difference. Fun as it was with minimal smoke.
Will asked me to post the details on my UORVA turbo for my H1 (centermount). It's sold by ModMafia exclusively. They market it as a "300HP" turbo. Not sure if that is a standalone claim or not - but I'm 100% positive I'm pushing at least that much with all of my P400's upgrades and doodads. I have it setup on a mechanical wastegate for max 15psi at WOT. There's still a lot of spring left to compress on the wastegate controller.
Unfortunately the only picture I seem to have of it is when I unboxed it and its not really all that big. I've got a few pictures of one installed on my old truck's (RIP Petunia) P400 that I'll try to find.
I found a good video from UROVA.
Yeah, if you notice in the video the 250hp kit is a cac with adapters to match the intake manifold, different db2 ip (I believe pushing 90cc), different injectors (most likely higher pop pressure and less restrictive cdr.
The 300hp kit has all that plus the turbo. I’m guessing that db2 is pushing 110cc or more.
My understanding is the UROVA turbo is very similar to an hx35/40. But without measurements of the turbo and without turbo mapping- it’s guess work.
The bad part is: they are a low volume manufacturer who was set up to sell to military purchasers. This means they usually leave a lot of room for improvements.
There is tons of people that have say an hx35, so we can do a bit of research and learn simple improvements to be made at home. The UROVA with measurements of pressure and flow along with physical measurements of wheels & housing could have pencil to paper by turbo aficionados and make descent improvements for power & mpg. With all the new blocks being made with the oil feed and drain with mounting bolts - fitting a centermount into pickups becomes a much easier task, and Hummers/ hmmwvs is an easy swap.
So I don’t think Mod Mafia is trying to lie to anyone saying adding only the turbo gets you to 300hp. Turbos are often rated at what power level they can support (get up to) as a maximum.
Does a twin scroll help out any? The exhaust flange is open single scroll. I would think a twin scroll would only benefit a twin scroll exhaust splitting the banks.
if the impeller was the right size since it would be getting exhaust from one head, that might work. since the truck engines use a crossover exhaust it would work. but mounting would be the issue. same as trying to drop a center mount humvee engine in a truck. you'll need a hood cowl to make it fit along with some firewall modifications
Although on my 93, there is a lot of room directly behind the intake, kind of a recessed area in the firewall. anyone have any pics of a center mount setup in a truck?
I always wondered what that would look like.
I assumed it was very hard to.make work or everybody would be doing it
Seems like I recall someone ether here or on another forum has a truck with a center mount turbo setup.
They say setting up dual turbos works too. you would need a second drinkers side manifold to go on the captain's side and just cap off the crossover section. someone here did this an had to customize that area on the manifold to clear the P/S bracket mount. never found out if running dial GM turbos was good for all around use or was a dog to get them spooling. maybe a set of t-3 style 4 banger turbos on this
No benefit unless your running a fully divide system, if so then it will help spool the turbo faster. I have a fully divided centermount turbo on my 6.5. not done yet..... on day.
