Big T
For my ‘99 K2500 Suburban?
Is there a linky ?I would go with PSC.
Summit has AC Delco PS Pump for $393, but you pay extra for warranty out to 5 years.Tool can be rented AND IS REQUIRED. Most parts stores you buy, use, return for $ back.
The original equipment lasts amazingly long, trouble free the whole time until it’s just worn out 99.99% of the time.
Then people want to save $2.98 and get a couple years of troubles and headaches until they finally sell the rig or spend the extra nickels.
Buy the original proper one not a different brand or reman imo.
That is for Duramax. More like this one:Marty asked for a link. here is their main site.
Power Steering - Hydraulic - Off Road, Hot Rod, Circle Track, On Road, Tow Rig
Modify your Jeep, truck, muscle car or off-road vehicle with cylinders, tie-rods and other high quality steering components from PSC Motorsports.www.pscmotorsports.com
Here is the one I believe fits our trucks, but it's best to call them and order what you want. they specialize in performance things and will build a pump to your liking new. even spec it out for volume if you later want to add a steering assist ram.
2001-2010 GMC 6.6 Duramax XD Series Pump Kit
Direct Replacement for AC Delco 19420690 Larger Ring and Rotor Produce for More Flow at Lower RPMS 1800 PSI Pressure Relief Valve Helps Turn Larger Tires Designed for 6.6L Duramax Engines with Hydro-Boost Brakes Uses Factory Power Steering Pump Pulley OEM Style Reservoir and Cap For vehicles...www.pscmotorsports.com
