dieselolds
Hey guys.I mentioned this in the 6.5 section but just figured I’d put this build info in the right place.Basically I have a 87 6.2 diesel with about 400,000KM on it that I decided to rebuild recently and have as a spare engine.I ran this engine for a few years in my 96 Chevy K1500 and I have to say it’s one of the best engines I’ve owned.It was definitely dependable and reliable the whole time.
It did suffer some hard starting issues in very cold weather but once up and running it was a great runner.This engine was pulled from a 87 Scottsdale 2wd 1/2 ton pickup.So back in 2010 when I removed this engine from the Scottsdale I had plans for it to be installed in my 96 Chevy that had the 4.3 vortec engine.
Before putting it in the 96 Chevy I decided to put new rod/main bearings in it for peace of mind with new oil pump and viton 2 piece rear oil seal.I also installed a new oil pan,oil pump driveshaft with Bosch glow plugs and new old stock 4153 injection pump with Delphi injectors.Before putting the oil pan on I installed a DSG stud girdle kit for peace of mind.So after doing all that it ran beautifully but just suffered hard starting problems which I blamed on leaky valves,low compression,etc.
So in its place in the 96 Chevy I put a 99 6.5 goodwrench engine in it with an unknown history.I painted it with red engine enamel,put new injectors,glow plugs and oil pump in it and I did not see any web cracks in it with the oil pan off.It runs very well but again it could fail tomorrow and blow to pieces.
A few weeks ago I decided to get the 6.2 gone through.It’s ready for pickup at the machine shop at this point but the machinist is waiting on the bearings to arrive.It’s crack free in the webs after a magnafux check,etc.Right now it’s been bored oversize for .75mm federal mogul pistons,align honed with arp main studs in place,decked,cam bearings in place with new expansion plug kit.I also have two reman 6.5 60 degree heads I want to put upon it that I bought from
ADF diesel in Quebec,Canada.
I also had the connecting rods fitted with new bolts from Leroy diesel with clevite bushings.The crank needed machining according to the machinist but now has a clean bill of health.I plan to use a new clevite camshaft,nos ford lifters made in 1994 with a 6.5 timing chain set with reluctor in case I need to use it in my 96 gmc that’s DS4 equipped.My 96 Chevy has the mechanical DB2 5088 so I have two 96 trucks.
I’ll post pictures of everything when I get things back from the shop.
