Ok, understand I’m not trying to cheap out and avoid fixing a good vehicle. I’m not against putting money into worthwhile vehicles. I have a 500hp Cummins in my Dodge that I built just because I wanted to. But the story on this truck is, it’s just a stand-in until I get my Dodge back together (fixing oil leaks on it and checking KDP). I really only drive back roads to work and back with the 6.5. (Keep in mind I live in the middle of absolutely nowhere, the nearest traffic light is over an hour away in any direction.)
I like the truck but it’s not worth anything really, I paid my brother $500 for it. I got it because I needed a truck, as my dodge is down, and I don’t want to drive my Jetta on gravel roads.
It has over 570k kilometres on it.
It has pretty bad blow by, but starts good when plugged in.
It leaks oil, and some coolant.
Also has a bad PS leak from the hydroboost.
The rear diff is, well, I’m not sure, last time I drained it there was pieces of roller bearing from the spider gears rolling around in the bottom.
I’ve hit four deer with it, not bad hits, but still didn’t help anything cosmetically.
She’s covered in dents, scratches and body rust.
Other than that it’s a solid truck
I don’t expect much from it, but it’s only a “gravel roads” or “going fence fixing in the pasture” sort of truck. That and it’s the only truck I’ll let myself put stacks on
so I sort of want to keep it alive still.
That’s all.
