Door Hinge Pin and Bushing Replacement
Big T
Fullerton, CA
Doing a little research on door hinge pin replacement on the GMT 400 era trucks, and came across this excellent video
Fast forward to the end and he experiences the exact same bushing break-up that I did and in short order. Lot of comments about the crappy Dorman bushings with some recommending GM only bushings. Then finally someone came up with a source for solid bronze heavy duty bushings:
They ain't cheap at $30 per door, but you get what you pay for. I ordered 2 sets because I'm tired of messing around. They even offer oversized bushings for door hinges that have worn.
Will let y'all know how this goes.
I too will await for your report on these. My driver door is already loosening up where it’s bouncing on the striker. Need to do all 4 doors and don’t want to have to redo it again and again lol
You were the one who motivated me to do the search for good bronze bushings. It was not a hard search. First found the video, which mentioned the existence of them. Then found the source in the comments. I’ve had the cheap Dorman bushings work, but not for long. You (should) know things have gone bad when the door is sticking and you’re pulling extra hard on the interior door handle to open it, eventually bending that handle.
Oh, this video is a whole guide on door hinge pin replacement. Such a discovery! Since I'm unfamiliar with the process of door hinge pin replacement, I was told to seek assistance from a professional locksmith Bermondsey. A locksmith can provide the necessary guidance and perform the replacement. However, this video is like a guide that shed the light on the whole replacement process.
Welcome to the forum @Tammara Pearse It's really not that difficult replacing the pins and bushing as long as you have something to support and lift the door or have a helper with you. there are some really good youtube videos out there showing all the details too. sometimes those videos help as showing all the details. it always helps me visually seeing rather than someone explaining it to me.
I have a few door tools that I doubt I ever use again.
The thingy that sits in the floor jack and holds the door and maybe a pin tool or 2.
Shipping would probably be too much. Given the tools aren't that expensive to begin with.
But if someone was in need and happened to be driving by
I could hook them up.
Welcome aboard Tammara Pearse. You will find this site loaded with people willing to help. I started this thread because this was my second go around replacing hinge pins and bushings. As you will find in the course of the thread, the bushings that come with the cheap made in China kits don't last if they even make it past the installation procedure. The posted video guides you through the installation process, but it also reference some custome HD sintered bronze bushings for which I posted the link to the manufacturer. Those bushings are the answer for a repair that will last long term and I would consider them an absolute must.
The installation process itself is not that hard. I've done it using an engine hoisting and ratchet strap and this last time I made do using ratchet straps over joists in the garage. Some use a floor jack, but you would need a second person to hold the door on the jack.
Good luck and report back on your progress and results.
See, and here I thought that was just spam adding a hot link to a lock smith- which never ever is the person to hire for replacing hinges.
My sillyness was thinking the software is scanning for posts less than a year old on repairs based around doors. I mean, are you happy to have a new King over Bermondsey @Tammara Pearse ?
Can ya post a pic of your diesel truck there in that part of London? Be kinda cool!
Hey! That’s a great find—videos like that can be super helpful when you're trying to understand something new like replacing a door hinge pin. I totally get your initial thought about calling a locksmith in Bermondsey—it’s always smart to consult a professional when you're unsure. But yeah, having a visual walkthrough can really boost your confidence if you want to try it yourself.
I recently had a similar situation here in Florida. One of the doors in my home was sagging slightly and wouldn’t close properly. At first, I thought it was a major fix, but it turned out to be just the hinge pins needing some attention. I contacted a local locksmith Florida service, and I honestly can’t recommend them enough. They were professional, super friendly, and explained the whole process to me while doing the job. It’s always reassuring to work with someone who knows what they’re doing and takes the time to make sure you're informed.
I needed the repair because the door wasn’t aligning well, which was affecting the lock too. Since security is super important, especially in this area where we’ve got a mix of city and beach homes, I didn’t want to risk it.
So whether you go the DIY route using the video or get a locksmith involved, it's awesome that you’re looking into it properly. Just make sure whatever route you choose, you feel confident and safe with the outcome!
