Steering Gear Identification, What's best for our Rigs, Can one be reliably be rebuilt.
dbrannon79
I'm getting there!
Seguin, TX
Hey guys, I have been reading up on the different steering gears and how the reman units have become a gamble on what you get in the box. I found a site online that shows the differences on some of the GM boxes, showing casting numbers and bore sizes. Below, each spoiler drop down will show some info in identifying these gear boxes. (I didn't post a link to the site because they sell these units and wasn't sure if it was allowed to post the link)
SAGINAW 800/808 GEARBOXES
This is the most common GM steering gearbox found in cars and small trucks from the 1960’s into the 2000’s.
The difference between the Saginaw 800 and the Saginaw 808 is the size of the piston. The 800 has a 70mm piston and the 808 has an 80mm piston. This is easy to measure from the outside of the gearbox. If you measure the end cap, the 800 is roughly 3” and the 808 is just under 3.5”.
Saginaw 800 gearbox measurement
Saginaw 808 gearbox measurement
It came in both a 3-hole “L” and 4-hole “H” mounting pattern. The 3-hole is the same pattern, just missing one hole and will fit directly into any vehicle that had a 4-hole pattern. They are much more common and easier to find cores, so we typically sell the 3-hole version. If you must have a 4-hole pattern it can be special ordered.
Saginaw 800/808 s-bolt pattern
Saginaw 800/808 4-bolt pattern
Pre-1980 gearboxes will have 5/8 and 11/16” SAE inverted flare fittings while gearboxes after 1980 will have 16mm and 18mm O-ring fittings. Again, the older SAE gearboxes are very hard to find, so the majority of the gearboxes we sell are metric. If you are installing into a pre-1980 vehicle that has inverted flare fittings, we can install a seat kit that will allow you to thread your existing hoses. Yes, the SAE thread pitch will thread into the metric threads!
Saginaw 800/808 O-ring
Saginaw 800/808 Inverted Flare
Along with the change of fitting style in 1980, the input shaft also changed from 13/16-36 (pre-1980) to 3/4-30 after 1980. You can simply change the rag joint to accommodate a smaller input shaft. When counting the splines, it is important to know that the 30 and 36 counts include any missing splines that are removed where a flat on the shaft is.
Saginaw 800/808 input shaft dimensions
SAGINAW 708 GEARBOXES
This gearbox was found in GM trucks and SUV’s up to 1986. It is easy to identify because it mounts on the outside of the frame and the mounting tabs are on the opposite side of the gearbox. Notice how the mounting holes are on the top side of the gearbox.
Saginaw 708 Gearbox
The one variable with the 708 gearbox is that it came with two different sector shafts. A threaded shaft (found in 2WD vehicles) and a notched shaft (found in 4WD vehicles).
Saginaw 708 threaded vs notched sector shafts
Gearboxes before1980 will have 5/8" and 11/16” SAE inverted flare fittings while gearboxes after 1980 will have 16mm and 18mm O-ring fittings. Again, the older SAE gearboxes are very hard to find, so the majority of the gearboxes we sell are metric. If you are installing into a pre-1980 vehicle that has inverted flare fittings, we can install a seat kit that will allow you to thread your existing hoses. Yes, the SAE thread pitch will thread into the metric threads!
SAGINAW GMT GEARBOXES
This gearbox is found in GM trucks and SUV’s from 1987 on. It uses a 3 bolt “triangle” pattern. This box has many variations!
Saginaw GMT gearbox
Piston Bore Size
There is a casting number on the housing of the gearbox (either 83 or 84). Casting number 83 is a “small bore” GMT400. Casting number 84 is a “big bore” GMT800. Most of the time: 1500 2x4, 1500 4x4 and 2500 2x4 use the small bore, and 2500 4x4, 3500 2x4, 3500 4x4 use the big bore, but there are some exceptions.
Saginaw GMT gearbox with piston bore size 83
Saginaw GMT gearbox with piston bore size 84
Blind Spline
Most vehicles use a sector shaft with 3 Blind Splines, but some (usually Diesels) have 4 Blind Splines. You will need to know which you have.
Saginaw GMT 3 blind splines
Saginaw GMTt 4 blind splines
End Cap Number
Some models of vehicles have different internal stops to limit steering travel. There is a number on the end cap that will let us know what stops you need.
Saginaw GMT end cap number
Input Shaft
It is also a good idea to verify your input shaft type. Vehicles from 1987-2000 should have a 3/4-30 splined input shaft and 2001 to present use a DD input shaft. Some models around the 2001 switch over may not follow these guidelines.
Saginaw GMT 3/4-30 input shaft
Saginaw GMT DD input shaft
If you have all this information you can go through the pick boxes on our website and order the gearbox you need.
I am still looking for identification on some Delphi gear boxes due to the fact that the old box I have that I am considering to rebuild for my truck has a Delphi casting number on it which I have not been able to id yet, might be a unicorn lol
based on the information I found, I have currently installed on my truck, a Saginaw GMT 83 cast (small 3" piston bore) with a 4 bind spline sector shaft.
The old one which is a reman unit is a Delphi unit with the part number 26078664 casted on the housing, also has the number 64 casted where the above info would show ether 83 or 84. It has a 3-1/2" piston bore size.
both gear boxes are suffering from the sector shaft side to side movement. I crawled under my truck today and wiggled the rag joint and found most of my steering wheel play is in the box having slack inside and the side to side movement.
I have already removed the sector shaft from the old Delphi unit that came off my truck a while back and verified that the play is ether from the roller bearing or a stretched housing. the shaft it's self shows no evidence of wear.
From what I have read online and seen in youtube videos, these gear boxes are famous for the housing getting stretched causing the side to side play where the pitman arm connects. this alone is leaving me doubtful that a person like myself would be successful in a reliable rebuild without having access to a machine shop to bore the housing and insert a bushing to take up the slack.
Does anyone have any input on what possible options we have rebuilding these gear boxes and making them last?
The majority of box slack that I have found is on the input bearing carrier adjustment. It is very critical to get adjusted and must be within an 1/8" of a turn to get the slack out. 5&6 lug trucks got the 83, 8 lug trucks should have the 84. You can replace the bearings(if you can get the right ones), but if you have problems in the torsional shaft or spool valve assembly, good luck getting parts.
I may try tearing the delphi box down tomorrow, I have not messed with the input shaft or the spool assembly yet. I am curious on the input shaft though, because before I pulled the sector shaft out I was rotating the input shaft back n fourth lock to lock. it takes three turns from one lock to the other, not sure what ratio that would make it. But when the input shaft reaches the stop turning to the left it stops solid like I would think it should. turning the input shaft to the right and when it reaches the stop it has a small amount of give to it (kinda springs back slightly). not sure if that indicates a problem in the torsional shaft or valve assembly.
looking online with the Delphi casting number, it seems this number was for a GMT800 truck around the 2004 models. it's a rebuild unit that was on my truck before. I pulled it due to slack in the steering and trying to figure out the stiffer than what I thought to feel normal issue. of course the box that is on the truck now didn't make anything better! rebuilt crap!!
I'm also wondering if scavenging some junk yards for a 84 series box with low mileage to rebuild might be a better option, leaving this delphi box for a core return.
The gmt800 half ton steering box can be adapted to the gmt400 trucks. RA at one time was selling some of them.
If you want a bulletproof, HD steering gear box, I know there's a couple of aftermarket companies that sell them and are listed in the Classifieds in DieselPower - one of which has been discussed pro-con on here recently.
