Well sumbitch, would you look at that!
View attachment 65368View attachment 65369View attachment 65370
Amazing how it actually makes cold air when your junk’s hooked up correctly. I ran out of refrigerant, but at least I’m finally on the right path. Thanks again for the help!!
That would be incorrect. As of 1-1-18 you must posses an epa 608 license to buy r134 in a cylinder larger than 2lbs for personal use. You can pick them up on ebay as it is legal to buy a 30lb cylinder without a license if you're going to resell it(explain this BS to me), so a few ebay sellers are working under the loophole.I hadn’t priced one in a while but a 30 lb. jug of 134a ain’t much. Last time I bought a 30 lb. jug it was a little over 100$. You don’t have to have a EPA card to buy it
Thanks for the tip and explanation! I’ll check it out.If you want to double check you didn't leak too much... Feel the inlet and outlet of the evaporator. IR gun measure them. They should be close in temp. If they are not it means the charge is too low and oil isn't circulating well.
Why? This system is a "flooded" evaporator meaning it is full of refrigerant with up to 1/4 LB in the accumulator. You have some leakage reserve in the design. So both lines are seeing liquid R134a boiling off and this is why they should be cold cold. Not Cold Cool.
This is helpful info, thank you. I have insulation around most of the hose so I can’t feel along its length, but I am able to feel it at the compressor. It was cold and still cold after idling for about 5 minutes. Should I check it at a higher rpm or is normal idle correct?Since you have the scroll compressor, it is not going yo perform well at idle. Feel the low side line coming out of the evap, out of the accumulator, and at the suction side of the compressor. You can feel the lines and tell where there is liquid, gas, or nothing. If after a few minutes of running you don't feel the suction line getting cold at the compressor, it's under charged. So long as you have enough charge in the system for gas to reach the compressor, you're fine. These systems cycle via a low pressure switch at the accumulator, they turn off at 18-22 psi(20-25 degrees F), and back on around 45-50 psi(49-54 degrees).
Oh and this was with the blower fan on high, recirc door open, windows open and the electro-viscous fan engaged. And it was around 90 degrees outside.This is helpful info, thank you. I have insulation around most of the hose so I can’t feel along its length, but I am able to feel it at the compressor. It was cold and still cold after idling for about 5 minutes. Should I check it at a higher rpm or is normal idle correct?
Makes sense. Thanks for the info.Idling under those conditions the suction line should only be cool at the compressor. I do not insulate the suction line from the accumulator to the compressor. Insulating the accumulator is a good thing to keep heat out of the system, but insulating the suction line can increase the chance of liquid refrigerant slugging the compressor. I always leave that line bare as a final stop gap to let any liquid to boil off before it hits the compressor. Compressors compress gas, not liquid, liquid hitting the compressor can be a death sentence for one.
