1993 chevrolet 2500 four
- Messages
 - 14
- Reaction score
 - 11
Pulling a 6000 pound trailer 1993 2500 extended cab with a 4L 80 E motor has 269,000 on the odometer what would be a safe high rpm for pulling hills with this motor seems to run out real well. I replaced water pump with a high output replaced with a Duramax fan aluminum radiator 4 inch exhaust can I use Amsoil 1540 change oil every 3000 miles. What would be the maximum rpm for pulling this load up a grade? I never run it much over 2200 the temperatures don’t get much above 170 but I did pull a small grade recently and the temperatures got to about 195 would it be safe to run this thing at 230pulling a grade? Thanks for any help!
