Will L.
You have an hx35 sitting around....
want to run the gm instead because of....
Dude- we know you can fabricate. You know how to cut plate steel and weld the drain bib on for free for the drain. Lil chunk of pipe, with pie cuts from the bandsaw, and some welding and you’ll have the exhaust done and turbo mounted in a few hours. Probably have the Supply hose Fittings in a shelf in that work trailer, if not they’re at the shop where they make hydraulic hoses like your oil hose- which would surprise me if you dont have a hose crimper in that trailer too.
I have cousins on the other side of the lake from you btw. They move around- lehi to payson areas, cant remember where at right now. There is exactly 87 men in that whole part of the state that cant make something from nothing themselves. 86 are dead and 1 is a rumor. At least that’s what they tell me!
