Rockabillyrat
SlIgHtLy StUpId.
I'm will Will L. On this one. It sounds like a glow plug issue to me. A amp clamp is hands down the best way to test them. You can watch total amperage pull and the amount of time they are commanded on. If you see low amperage then jump the glow plugs manually with a wire and measure your amperage again. If your amperage is still low you have a GP issue, if it's normal when manually jumped you have a module or power issue. If your amperage is good but your on time is too short, you have a module issue, or a bad sensor causing the glow plugs to short cycle. Manual jump them for and see if its start better. That will confirm a module or sensor issue.
Also you can watch the advance piston servo movement and see if its pulling up for cold start advance.
