Landon730
Active Member
Ever since I got my truck going after buying it in limp mode.. I've noticed that its nothing compared to the lb7 my dad had. Slowly it gained a injector knock... I'm only 16 so I can't afford a tool to read my balance rates to figure out which injector is bad (I can afford one MAYBE two injectors) . I can tell its the drivers side but I don't want to play a guessing game with something this expensive and I don't want to do like I did with 6.5's and break injector lines loose. The truck does just fine driving to work and hauling light loads but if you really start to load it and pull the knock gets extremely loud when you stop for fuel. I hauled a feeder on a gooseneck about 300 miles and that was the loudest the knock ever got. Almost sounded like a rod it was so loud. There's never smoke when pulling and just easing around but you can definitely hear a problem. I just need ideas on how to find out which injector is bad without breaking the bank. I want to get it fixed soon as I've already ran it about 3000 miles like this and just besides the fact of it being ridiculously annoying, I'm worried its not to good for the motor.
