Jerryjerry05
Member
Hi, I have 1995 Suburban 1500
It has the 6.5L Turbo Diesel.
Full tank of fuel.
Yesterday driving down the road it acted like it was running out of fuel.
Stalled and towed home.
No fuel at injectors.
The lift pump only works if I jumper the lugs in the board where the relay plugs in.
It pumps fuel to the filter and out the little drain on the top.
The relay is new the fuel is clean.
I'm leaving the jumper in the board to keep the lift pump working.
What else is operated from this relay?
Would it hurt to leave the jumper in place?
Or could I put in a switch and operate it when running?
Should the lift pump shut off when it reaches a certain pressure?
Is there a fuel pump pressure switch in this system for the lift pump?
Any help would be appreciated.
I read the 4th post about the lift pump and circuts problem.
It's kinda like mine.
How would you check the injector pump or that system.
I'm a marine mechanic and have tools just not the knowledge on diesels.
Full tank of fuel.
