Will L.,
IF we still had our old diesel farm tractor, I wouldn't be afraid to run that old & "un-finicky" BEAST on most anything that will burn.
(We ran a lot of filtered waste motor oil, "French fry oil" & "stock feed-grade" cottonseed oil in it, W/O problems.)
yours, satx
The first concern you should have is shutting off the air in case the IP sticks wide open on you. Have a plan.
And parts for the injection system on this tractor are even available and cost what? The least amount of damage is ruining the entire injection system. The most amount of damage is the malfunctioning injection system takes the engine completely out. Say an injector sticks open - it will melt the piston and the rod will ventilate the block without guidance from a non-melted piston. The 6.9 is a slightly more expensive engine than the 6.2/6.5. The above "experimental fuels" are NOT old bad fuel.
It would be a shame to ruin it over running old bad fuel through it. After all you are going to change the engine oil no questions asked right?
This is an example bad fuel and bad things happen "when you don't get away with running garbage through an injection system":
http://www.thetruckstop.us/forum/th...ulsd-and-biodiesel-this-can-affect-you.35096/
It's waste oil. Usually can be disposed of with used engine oil. Look for boat mechanics and call them about disposal. Look up "Fuel polishing services" and ask them for disposal options. Boats sit and experience these problems way more often than vehicles do.
The return lines for the system should go into a bucket, not your clean tank until the system is flushed. You got a quart or so of what used to be diesel in the IP.
I tore into a NOS 4.3 L Olds diesel V8 donated to a engine tech program by GM for educational use only. (No typo the rare small V8.) It had sat around for better than a decade, perhaps nearly 2, and no one had ever bothered to tear it down and reassemble it for the shop class. The yellow varnish that poured out of the new, but, ruined from sitting injection pump was no longer diesel. Had I wanted to "repair" the engine for use from a customer estimate standpoint I would have had the IP sent out, cleaned, resealed, flex ring upgraded, and tested if possible to even save it. Injectors cleaned and tested as well. Old fuel can turn acidic and etch the parts in the IP.
