Aishling
West Australian
I cant tell if the fuel pressure goes up before lights-out or just after. It's all I can find as a symptom.
Dont forget I am in Australia !! No parts stores or anyone familiar with GMC/GM Diesel problem-solving.
Problem: Stopping when accelerating engine.
I have been suffering intermitent stalling for a while. Ute (Australian for little truck) usually starts instantly without issue whilst still rolling.
I ordered new FSD and Extension cable, new Pump pigtail, new Ignition key wiring pigtail, new fuel shut-off solenoid (on IP).
While waiting for shipping to Oz- problems get worse as in more regularly stalling (eventually daily) and wont restart quickly. Longer waits between start attempts are successful. Eventually almost impossible to get going (starts and then dies quickly). I have taken apart all wiring in engine-bay and checked and dialectric-greased joiners.
Parts arrive - I replace the FSD and extension cable (thanks Leroy), and the Fuel shut-off solenoid. I replaced the fuel pressure guage between filter and IP. I did some driving around the farm - all seemed good. In afternoon I hitch-up 5th wheel horse float, load and leave. ute drives 1000Meters and stops. restarts easily. As soon as I accelerate it stops. Harder to start after the second stop. This cycle gets worse. Quicker shut-down and slower to recover to be able to restart.
After thinking about it I checked the return fuel-line flow by pulling-off the hose from IP. Plenty flows out. Ute starts well and I return to farm with a few stops (gets drastically worse along the 100M trip). I used aircompressor and blew out return fuel-line with tank cap off: seems fine. I set off again and got further but still gave up and went home.
A day later I removed FSO solenoid and it seems to work fine. I can start and idle almost indefinitely. 6PSI on fuel pressure guage. If I gently press accelerator and raise revs (1000) the moter will die soon (20 seconds-ish). If I stab the accelerator it will die immediately. Fuel pressure observed to go up to 9PSI at engine dieing.
It's got me f_cked....
Demographics: tell us about your truck and your ambient conditions:
- Year: ____ ____________________________1998
- Truck model and class (ie: c2500) _________K2500 Sierra
- Automatic or Standard _________________700r4
- Mileage: (indicate miles or km) _________ 190k Kilometres
- Replaced parts and mods ________PMD, chip/PCM is now KOJO, AT Turbo, Diamond eye exhaust and new 2.25" crossover.
- Model: VIN 1GTGK29F-4WE547828
- Ambient outside temp: (indicate 23 *C
- What fuel are you using? Best quality diesel
- What fuel additives are you using? Morey's oil diesel additive
- Where are you located? South-West of Western Australia
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter _________10000Km (K47 style)
- Fuel filter _________ 5000Km (big Donaldson 5Micron with water bowl)
- CDR Valve? _________ Unknown
- Coolant – last flushed/replaced at ___4000Km
- Oil – synthetic/regular, changed at __Mineral 5000Km
- Batteries – state of charge, (matched set) replaced at. Good, unmatched except chemistry, 3 months old.
- Battery cables and grounds (removed, cleaned and tightened): new about 10000km. cleaned
- Glow Plugs - how many miles on them? 5000km What type? Bosch
- Injectors - last changed at Unknown. new ones here to go on.
History: (Describe how the problem first appeared.)
- What were you doing when it happened? ______________ Towing 4000Kg
- How was the truck running fine before this problem appeared? perfectly except intermitent stalling
- Has this problem ever happened before? simple stalling yes- but always restarts easily.
- Describe any related factors that might be part of the problem. just changed FSD
- Have you checked for DTC (Diagnostic Trouble Codes)? Yes P0308
[/FONT] Diagnostics:
1] Starting:
1a] Does the engine start? _________ yes
1b] Does the engine crank over? ________yes
1c] Are your batteries fully charged? _________yes
1d] Have you removed, cleaned, and tightened all battery connections? ________most
1e] Does your Wait to Start light come on for a time? How long? _________5 -10 sec
1f] Does your glow plug light come on? _________ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? none (then black belch when starts)
1h] Does the Service Engine Light Glow during Start/bulb check? yep
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____________yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________ yes
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________slight
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___________remote - bumper
3b] Condition of Extension harness (if used) Vendor or Homemade? _________Vendor new
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________checked, extras added.
3d] PMD Make: ___________ Flight systems
3e] PMD Age: _____________new
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________ usually
4b] Does it stall under particular circumstances? at the moment at accel
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________ used to - not now
4e] Does SES light come on when engine hiccups? _________no
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________no
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___________ not working
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________Kojo
6d] Have you changed exhaust / downpipe / crossover? ________________DEye and cross
6e] Wastegate – mechanical or vacuum (OEM)? ______________ None
7] Temperature-related Issues:
7a] Single or dual thermostats? ____________ Dual
7b] Have you replaced them lately? Manufacturer of replacements? _________10000Km Tridon
7c] Have you pulled and cleaned Radiator and coolers lately? ____________New 2000Km
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
List and describe any other factors which are not addressed in this checklist.
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
