Bernie
Amateur Radio Operator - KJ4VOV
So, as some of you know, the wife and I are in the process of moving from Fredericksburg, VA to Anchorage, AK. Part of the preps for that involved me driving up to Buena, NJ Friday night to pick up a new trailer (6x12 SA enclosed) to haul stuff up there in. Going up the truck ran well, but not quite the way it usually runs. Seemed a little weak on power at times. Coming back with the trailer though I got about 100 miles and started loosing power and had the SES come on. The truck'd cruise okay once it got up to speed, but getting there took forever and involved quite a bit of black smoke. Not "rolling coal" levels, but this has always been a clean running truck. Took forever to get it home like that but I finally made it late last night. Still haven't even unhooked the trailer, just left it attached and parked on my driveway.
Once I've had enough coffee and pain pills to ease the aches from the drive I plan to go see what's up with the truck. I don't have a scan tool, so can't pull the code(s), but my thought process is running along the lines of either a bad injector, injector pump problem, or fuel flow problem, and here's my reasoning: the black smoke tells me I've got a lot of unburned fuel, and the most likely cause of that is bad spray pattern due to bad injector or an injector pump not having enough pressure. Working with that assumption I'm starting with the simplest thing first. It's overdue (really overdue - like 10k miles overdue, because I forgot
) for a fuel filter, so I'm starting with that. I have a spare behind the seat so I'll pop that in and see if it helps. If not, then he goes to a local shop Monday for diagnostics. I'm really hoping it's not the pump though, as that's an expense we could do without right now, and might be enough to tip things in favor of selling the truck.
(Truck's a '99 GMC C3500, 6.5 TD with 112k on the clock. Injectors were replaced at about 104k. PMD is remote mounted)
