Jorge6.5
That's nuts how they can be totally nazis and not even conduct the test in the proper manner. In NY there is no emissions test for diesels over 8500lb gvwr
What an ordeal!!! I'm glad you finally got it passed. I am so glad I don't have to deal with that smog check here. I wonder if I could be as patient as you've been. There's only two places here in Oregon that do checking, Portland and Medford. I could never stand to live in the Portland area, too many people. The population of the Portland metropolitan area is over 2.2 million. The Medford metropolitan area population is just over 200,000, still too many people. I spent two years in Grants Pass which isn't all that far from Medford.
Don
You make me so happy to have a '94. Thanks for the adventure story.![]()
I would like to tank all here for their support, particularly Handcannon for his catalytic converter which will come off this weekend like a bra after the Senior Prom. So, I will swap turbos, remove vac pump, swap exhausts and pack all the smog goodies away on Saturday and head up to Big Bear with some new furniture for the place. The wife has already notified me that she needs the Burb to do some geocaching in the desert. Man, what an ordeal.
:raincloud: I will rain on this parade because this is such a bad idea. :suicide: I suggest you have something that looks like or is a cat somewhere on the exhaust all the time! :blindfold: This way they don't have to "take a closer look". You already had a clear warning on just how much that state will screw with you for this being missing. That is clearly intentional.
A melt down and break up that blows the innards clean out happens. Engine may stall a few times... How are you supposed to know yours did?
Do you want to go through this again if CA brings back or still does the roadside emission checks?
Everyone involved at the state is patting themselves on the back for bringing this vehicle into compliance and justifying the emissions tests 'we' suffer through.
The Duramax cat on my 4" exhaust is bigger than the muffler. It is clearly a cat in the mirror they use to see if it is there. I have enough trouble with the measured snap smoke test without other things for them to complain about.
Congrats on passing and overcoming the 'mistake'. I merely suggest you don't set it up to make it again...
Here's a link to an article explaining the direction in smog testing is away from tailpipe testing and towards OBD II systems checking:
http://www.arb.ca.gov/msprog/smogcheck/march09/transitioning_to_obd_only_im.pdf
I'll note that it applies to '96 and later OBD II gasoline powered vehicles. Apparently the OBD II system check is not necessary on my diesel truck.
A final observation, the smoke test is purely subjective. The final test station did the snap test and commented "Greg (ie the referee) passed you on that?" Well Greg the referee said "it smokes on start up but I can't fail you on that. It's based on whether there's smoke after snapping the accelerator and how long that lingers. He was comfortable with my smoke. Plus, with the B99 it smelled like French fries, super sized.
I'm waiting to hear Leroy's longer term results on his tune, specifically for mileage and smoke. Also waiting to hear more about the injector nozzles with 3 year warranty.
At Last!!!!![]()
Toward the earlier question of a permanent solution to this mess, the only low level of effort one that I could think of was to find a twin out there and put all the OE stuff in the 'spare' burb. Then every two years, yank the wind screen, swap VIN plates (presuming the inspectors actually compare the notice to the plate), and go pass the 'swim-suit' inspection again. Yeah, I know, probably not a helpful idea![]()
