Car is a stock, except the exhaust. I have checked all the connections, manifold, turbo, vacuum pump etc. Nothing wrong there. The problem began after one of the batteries went short circuit. I tested the other battery and replaced alternator. After that, boost pressure startet to drop in heavy acceleration. I thought it was the air cleaner, I took of the Accel cleaner and put the original box. It helped a lot, never wouldn´t believe that OEM beats high perf. cleaners, but it does.
It did lid the engine light couple of times before the battery went dead, it happened when I rode hard for little longer, highway speed around 140 kmh. But I never noticed any problems with boost. Before the battery incident, on acceleration boost went up to 8 or 9 psi max and dropped from there around 6 psi and stayed there as long as I keep the pedal on the floor.
I have now a new MAP sensor and pressure solenoid, I`m going to change them today and check the vacuum pump.
Is next thing the ECM ?
