Hi All
Brand new here, and a brand new owner of a 97 Suburban 6.5. I have a strange problem and I am wondering if it is related to the above. Picked up the truck today and it ran perfectly on the way home, over an hour's journey, stopped off here and there, shut off, restarted, no problems, ran like a top. I parked the truck at home, moved it a couple times, still no problems.
I then started to do some cleanup stuff, polishing and so on, left all 4 doors open to air the vehicle out and pottered around doing some polishing and buffing of the paint on the hood (that took over an hour). I then sat in the truck (still with the doors open) and started playing around with a little FM transmitter so as to play my iPod through the car stereo. After a while I then decided to start her up and idle for a while (to make sure the batteries were OK, and also just to hear the engine running
). It ran for about 30 seconds and then cut out. Hmm.., started up again and same symptoms. Started up again and went for a short drive, seemed to be OK and parked her again.
About an hour or so later, I needed to pop over to the store to pick up a couple things, that is when the fun started. THe engine cut out while driving, like the ignition had been turned off. I though maybe the fuiel gauge was wildly inaccurate (it was showing between 1/2 and 3/4). Managed to get to the gas station eventually (after numerous cut outs) and filled her up with some of the finest Arab Elixer. It took about 80 litres, so there was still plenty fuel.
Took a few attempots to get her running again and got home eventually.
Now, I am wondering if perhaps leaving the doors open and with the ignoition on may have triggered some kind of anti-theft thing (???). As I said earlier, it was running perfectly until before that. (PMD decided to give up the ghost????? Maybe??? I have no idea, but I am confident it is not fuel related, when it is running it runs beautifully, with loads of power)
Any help would be much appreciated
