6.5L
Old Iron Runner
So I was looking at my QSV and I have come up with a theory I think is sound now. No margaritas were harmed in the making of this concept. So I attached a picture of the actuating arm on the BD unit. Spring tension inside the housing keeps the valve closed. Boost over comes spring tension and pushes the arm open. There is a fair amount of thread to play with. I think if I simply loosen that nut, back the arm off a few turns to reduce spring tension, and then re-tighten the nut, it will lower the opening pressure of the valve. The valve operation won't be affected since the position of the connecting arm (see photo for shitty descriptions of what I am talking about ) doesn't change, spring tension will still hold it shut, and boost will still overcome it. Valve position and operation isn't being affected, just spring tension. And it will still only takes a certain number of psi from closed to open no matter what psi it starts to open at since the valve still only has so much travel allowed. What do you guys think? I am going to mark it where it is, change it some, and then take it out for a test drive and see where my non-alcoholic theory gets me. And yes, I know I have a slight exhaust leak in the picture. That is soot. I dont think it is a large leak since that is all that has accumulated since I installed the valve. Maybe from when it starts up when it is cold and there are some clearances. Could have also been from before I tightened everything down again. Who knows?
