L98TPI
We just put a 98 engine in a friends 96 Suburban, now down to the last hookups. I knew there was going to be an issue with the 1/2 NPT oil cooler in out ports in the newer block because of the bigger oil pump to feed the piston squirts. I did noodle around on here and used Rock Auto to research and I am still a bit confused. The issue is of course how to deal with the stock oil lines not fitting the 1/2 NPT snap couplers. Now the first sorta red neck reaction (I never do that
) might be to get a couple of 3/8 to 1/2 adapters, bend and maybe leave out the bracket screws, and make it work. But I don't do things half A$$ed. :rolleyes5: And you will have the issue of the factory didn't upgrade the oil cooler lines for no good reason.
There seems to be 3 or maybe 4 pairs of part numbers for just the oil cooler lines for the late trucks with the cooler in front of the radiator. In fact when this Sub had an oil line leaking out on the road, the diesel truck shop that worked on it got the wrong lines the first time they ordered, severely holding up my buddy on a work related trip. There also seems to be two oil coolers, :skep: not sure about that. Both the 96 trucks I have here, have 20mm nuts on the cooler end of the lines. I was not sure about the cooler on the subject truck until I got it to my shop today, not knowing what the previous guys did over the parts confusion.
The straight up way to go might be to buy the last design (97?-00) lines (40$ ea) and cooler (88$) so up grading to what the late trucks have. Not all that pricy either. Besides I can use his really new lines on mine. :hihi:
Opinion please.
Opinion please.
