HighSierra86
Active Member
Ok so i need someone to compare notes with....Ive been seeing some low pressures with my new fuel system set up. Im running a new walbro FRB-5 LP with a 30 micron racor pre-filter and the stock filter in the engine valley. I have my pressure tap right before the IP and have verified the pressures with a second guage at the t-valve. All filters are new.
I am seeing about 4-5psi at idle and about the same while driving. Lowest pressure i saw was just under 3psi but never above 6psi. Guage seems to spend alot of time in the 3-4 range. Now what I am wondering is if these are normal numbers, or a bit on the low side. The pump is advertised as a 10psi pump, now I didnt expect that but maybe more along the lines of 6-8psi.
My stock LP was running at about 6-9psi, now that is obviously with the smaller lines/less volume, and no pre-filter. I would be much happier with some higher numbers especially considering the truck is running a stock PCM. Im hoping to reflash in the very near future but Im not gonna do it until I know I am supplying the IP with enough fuel.
If anyone could share their findings I would appreciate it. My next step is dropping the tank again and remove the sock...
-Nick
-Nick
