btfarm
America First!
I find that I need to add a bit of power steering/brake boost fluid for the first time. Cold (45* F) the level is about 3/8" below the cold mark. The Diesel supplement says some GM number but no SAE equivalent standard. I see there is signs of a slight mist around the hoses at the boost unit that accumulates over several months after an underhood washdown. Should I siphon out what I can from the reservoir and put in new fluid? What fluid should I get? I'd rather not be buying it from a dealer.
