Problem: Explain your problem in concise language (ie: Cranks but won’t fire). Truck stalls (does not die) when in second gear at around 2000 rpm doesnt improve until it makes it to third gear, then stops completely except for a few rare fishbites. This happens when the truck is cold and when the truck warms up to around 180 the stalling stops and is limited to fishbites that are random.
Demographics: tell us about your truck and your ambient conditions:
- Year: 1995
- Truck model and class (ie: c2500) K3500
- Automatic or Standard Auto
- Mileage: (indicate miles or km) 195000
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) Complete front end rebuild, glow plugs, injectors, fuel pump, PMD relocated (done by PO unknown when done)
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR?
- Ambient outside temp: (indicate *C or *F) 60 f
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _________
- What fuel additives are you using? ___________
- Where are you located? midwest
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter just replaced
- Fuel filter just replaced
- CDR Valve? _________
- Coolant – last flushed/replaced at just replaced
- Oil – synthetic/regular, changed at _just replaced__________
- Batteries – state of charge, (matched set) replaced at _very recent____________
- Battery cables and grounds (removed, cleaned and tightened): ____yes__________
- Glow Plugs - how many miles on them? ____100_____ What type? _____________
- Injectors - last changed at ______just replaced_________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? _____coming from dead stop at sign_________
- How was the truck running fine before this problem appeared? _____yes started as small fishbitting________
- Has this problem ever happened before? __________rarely_____________
- Describe any related factors that might be part of the problem. _____bad transmission wiring (fixed)_________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __y__ And? ___none_____
Diagnostics:
1] Starting:
1a] Does the engine start? _________y
1b] Does the engine crank over? _____y___
1c] Are your batteries fully charged? __y_______
1d] Have you removed, cleaned, and tightened all battery connections? _y_______
1e] Does your Wait to Start light come on for a time? How long? _________
1f] Does your glow plug light come on? ___y______ For how long? ___2 min maybe______
1g] Do you see smoke from the exhaust while cranking? What color? ___n_____
1h] Does the Service Engine Light Glow during Start/bulb check? ____y____
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____remote in front of radiator_______
3b] Condition of Extension harness (if used) Vendor or Homemade? _____vendor____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ___good______
3d] PMD Make: ___________
3e] PMD Age: _____________unknown
4] Stalling Issues
4a] Do you experience stalling only when hot? ______n______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __accel 2nd gear____
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________yes
4e] Does SES light come on when engine hiccups? _______no__
4f] Does cruise control quit working when engine hiccups? __unknown_________
4g] Does re-starting seem to reset engine, restoring cruise and power? ___n/a______
4h] Changes to dash lights or instruments during stalling events? ____no_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______n
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____n______
5d] Excessive white smoke from exhaust on cold start? _____n____
5e] Excessive black smoke from exhaust under hard acceleration? _____n_____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___________n
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? _______n_______
6d] Have you changed exhaust / downpipe / crossover? __________new oem______
6e] Wastegate – mechanical or vacuum (OEM)? ______________
7] Temperature-related Issues:
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? ________n_
7c] Have you pulled and cleaned Radiator and coolers lately? ____________n
7d] Have you replaced the fan clutch? Manufacturer of replacement? ______n__
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________n
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you.
_________________________________
